Possesed Oil Pressure
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sparky, Apr 25, 2001.
  1. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    My trucks moter is showing some age. When I fire it up it runs up around 60-70 psi. When I drive it on the highway for an extended period (more than 10 or 15 min.) the oil pressure start doing strange things. Around 70 mph and 3000 rpm the oil pressure will start to jump without a change in speed or pedal. It will bounce slowly back and forth between 45 and 25 psi. The faster I go the larger the changes, and the lower the pressure gets. Sometimes it will jump to 20 psi at 3500 rpm. At idle it has a little under 10psi in gear (600 rpm) and about 12 or 13 in neutral(750 rpm). The 350 does not burn a drop of oil and it runs clean and well (passes 97 year emisson testing without a lick of smog equipment). What would cause this to happen? Just worn bearings, or something else? Anyone else had this problem? The number should be acurate as they came from two different mechanical gages.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Maybe you got some junk floating around your motor or in the sending unit. Run some Marvel mystery oil in your crank case and replace the sending unit. That's what I would start with.
    <A target="_blank" HREF=http://k5chevyblazer.homestead.com/home.html>http://k5chevyblazer.homestead.com/home.html</A>
  3. Sparky
    Aug 20, 2000
    423
    There is not junk in there. I have had the oil pan and valve covers off too many times since it started for that. All is clean. And I dont have a sending unit. Its mechanical.
    Sparky
    78 K-5
  4. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    try checking your gauge - There could be something occluding the Bourdon tube, causing it to be erratic.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    could be fluctuations with the oil draining from the motor back into the pan. Check to see if the drains in your heads are clear of sludge. 'Specially near the rear of the motor. Sounds kind of far fetched but you never know. I met a super mechanic from Mars years ago(this guy was a freak) I was having problems with smoke, figured my rings were toast. He cleaned out the oil drain holes and it never smoked again. I complained about my gas mileage. He listened to the motor and told me to change my battery, it was dead. I blew it off, 2 days later it died, I bought a new one and my milage picked up. Wish I could find him again!!!.
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
  6. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    I recently replaced the intake with a high rise and the same problems you are experiencing started. I found that the wire to the sending unit had come loose...causing the erratic readings. I just tightned it down and the problem dissappeared.
  7. behemoth
    behemoth 1/2 ton status
    May 16, 2000
    1,833
    Northwest Florida
    ..".Marvel Mystery Oil" ????? Please explain! I'm having similar problems w/oil pressure.
    behemoth K5
    "Better to remain silent and be thought a fool -
    than to open your mouth and remove all doubt"
  8. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    On my 87 305 with the stock electric gauge, I've NEVER had oil pressure below 30psi. Of course, if I tap on the gauge lens, the reading changes drastically. So I'm installing Autometer gauges now.
    [​IMG] Semper Maintenance!
  9. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    you can put it in your crank case and it will clean the bottom of your moter. you can put it in the gas tank and it will clean the top half of the motor. It's great stuff! If your oil pressure is going crazy, then chances are it needs to be replace though. i would run that marvel stuff and then replace the sending unit.
