possessed headlights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by DOUGHBOY, Nov 20, 2000.
  1. DOUGHBOY
    DOUGHBOY Registered Member
    Oct 8, 2000
    68
    central illinois
    on the way home from work tonite,some dummy pulled out in front of me(must not have see me 1am im the only one driving down the road)i slamm on my brakes(didnt sqeall them but hit them pretty hard and, poof all my light go out dash,headlights,taillights,flashers everything.i drive up the road pull into a parking lot get out then they pop on.everything was fine the rest of the way home.what gives.any ideas.this happened to anyone else
    guns dont kill postal workers do.
    CENTRAL ILLINOIS
  2. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Do you have a body-lift or loose bodymounts? Loose ground-strap from batteri to chassie.. Just guessing. Locked my tires the other night too. Started thinking about all the warnings I'v had about the 3" bodylift I have.. Nothing mooved though, just a litle scary..
    http://www.espen88k5.coloradok5.com
  3. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    I had the same thing happen on my 83 jim. It didn't start by slamming the brakes though, only just braking. then when i would accelerate the lights would "pop" back on. talk about a nuisance. I never did work out the problem. All I did was find the main power coming from the firewall, and splice in a new power wire. I never had that problem again. Interesting to hear about the same weird problem.......js
  4. DOUGHBOY
    Oct 8, 2000
    68
    central illinois
    hmmm....i dont have any body lift.ill check all the ground straps.i guess ill see if it does it again on the way home tonite.if it does it again ill try and splice in a new hot wire and ground.thanks
    CENTRAL ILLINOIS
