possible broken axle?
Discussion in 'The Garage' started by bigboyblazers, Aug 12, 2005.
  1. bigboyblazers
    bigboyblazers Registered Member
    Jul 31, 2005
    12
    ellinwood,ks
    my drivers side tire sticks out about a half an inch farther than the passenger side and I get a loud popping noise from the front. could it be from a broken axle? I pulled the diff cover and didn't see any metal flakes. also should the spider gears be able to move up and down on the cross shaft, mine moves almost a quarter of an inch.
  2. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Probably not a broken axle. Check to be sure the axle is bolted good to the leaf spring; sometimes the centering pin in the spring can break
