Possible Driveline Probs with the 0 rate leafes
Discussion in 'OffRoad Design' started by zcarczar, Mar 2, 2002.
  1. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Im thinking about getting the 0 rate add a leafs for my k5 with a 4"lift, i was goin to keep the axles centered but i think i could use the extra inch of clearance because im running 35x12.50's on a 10 inch rim, but my dad thinks i will get drive line probs since it may make the front or rear shaft too short
    BTW- the transfer case us droped
    My Website<a target="_blank" href=http://www.zcarczar.com>www.zcarczar.com</a>
    89 K5 350 TBI 35x12.5.15 BFG's 4" lift
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The best way to tell if it's going to be a big deal is to jack the frame up 1" and see what it does to the shafts. That way you'll know for sure. That's all the zero rates will do. You may see some pinion angle change also but that generally has a fairly small effect on the driveshaft length.
  3. zcarczar
    Feb 10, 2002
    2,495
    Alright thanks, i will try and talk my dad into ordering me some of those for my blazer
