possible engine transmission failure
Discussion in 'The Garage' started by 88jimmyguy, Sep 14, 2003.
  1. 88jimmyguy
    88jimmyguy Newbie
    Dec 4, 2001
    plattsburgh ny
    ok... I have a 88 jimmy 5.7 liter 700r4 np208. over the last several weeks i transmissin problems. the jimmy doesn't /forums/images/graemlins/1zhelp.gifwant to shift through the gears. the engine whines out before the shift, shifts hard. then today, the engine died.
    no smoke sounds or fluid leaks. the engine turns over recieves fuel but doesn't fire. any thoughts thanks for all the help....
  2. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    first parts sounds like leaky vacuum or bad fluid. second part sounds like timing way off (stripped cam gears?) or corroded distributor rotor
    also- why'd you wait almost two years after registering to make your first post!??!
  3. funkycold
    funkycold 1/2 ton status
    Apr 22, 2002
    435
    Orange County, CA
    not sure about the enigne dying but the tranny needs to be rebuilt or replaced. I had the same problem and some grinding noises coming from the rear of the sub and i thouhgt it was the rear end. had the tranny replaced and the grinding noise went away.
  4. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    On the 700, it isn't going to be vacum... they don't use it. Check your TV cable adjustment (not sure where I saw it... but somebody has a real good write up on how to do it). Also, it could be a governor... but when my 700 had these symptoms it did require a rebuild /forums/images/graemlins/frown.gif. The engine not starting like that could be an ignition module... had that happen once too!
