Possible rear window fix?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by ryder, Nov 22, 2002.
  1. ryder
    ryder Registered Member
    Nov 14, 2002
    8
    portland, or
    The two tracks that are holding my rear window (73') are rusted and need to be replaced, but the rollers are also completly shot, kinda oval in shape and very loose. Instead of replacing the entire mechanism I am going to remove the old posts and rollers and replace them with a bolt and bearing. It is the only thing that I can think of to save on a little cash. Any opinions or suggestions would be greatly welcomed.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    That will work, you could also probably go down to your local window repair place and get from them what they use....new roller that rivets in place. Just an idea.
  3. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    LMC sells replacements for $4.95. I have not ordered them yet but I am going to after I confirm this info:
    The rear roller has the same part number as the door windows. If you compare the two on my truck they are different.
    Anyways, if they are indeed for the back window, you can't beat five bucks.
  4. lt61173
    lt61173 1/2 ton status
    Apr 9, 2002
    105
    Republic, Pa
    I got the rears for mine from lmc & they work fine.
  5. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    im putting a pickup cap door on the back inplace of my window..
  6. nofeartruckin00
    nofeartruckin00 1/2 ton status
    Oct 5, 2001
    798
    Germantown, Wisconsin
    Did you make that capwindow work yet? Just kinda curious how you are going to fab up the hinge/mount. /forums/images/graemlins/smile.gif
