Possible to break a FF14b?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by jekbrown, Aug 23, 2001.
  1. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    Ok, before I get any wise guy "sure, you CAN break anything!" responses...let me qualify. I mean under relatively extreme 4x4 conditions. Rock climbing, mudding, trail driving etc etc...no trying to jump 50' off of big sand dunes or other silly crap, just good hard 'wheelin. That said, how tough is that ff14b? I never ever see trusses for them (or on them!)...nor do I ever read "have this axel? heres how to make it stronger!" articles in 4x4 mags...so whats the deal? Is it pretty much indestructible? Do you even need to get chrome-moly axels for it or is it strong as hell in stock configuration? If some stock parts are a problem, which ones are they? If you did break one, what part(s) would be the most likely to go? Down the road I'd love to get a cheap junk yard 14bolt from a van and get it under my '85 Jimmy...that would rock. =)
    J
  2. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    I wont go into how indestructible they are (they pretty much are [​IMG] ) But I am pretty sure a 14 bolt from a van will NOT fit ... maybe someone else could clarify that ...
    1977 K5 Blazer [​IMG]
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Van axles require that you move the spring and shock mounts.
    I have never seen a 14 FF break.
    If you do break one you are truely amazing.
    <font color=green> Too bad ignorance isn't painful </font color=green>
  4. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    14 bolts are bomb-proof in stock configuration. I'm sure they can break if the gear lube is never checked and gets too low.
    Spontaneous axle breakage I've never seen, again I'm sure someone has done it but I'm sure its very rare.
    Weak points seem to be wear and age issues. Quite a few 14 bolts end up needing speedi sleeves on the spindles because a groove gets worn from the seal and usually mud or dirt and then they leak...its on my list of thing that need doing.
    Factory gov-locks in the 14 bolt suck...well all gov-locks suck.[​IMG]
    Paulie, the van 14 bolt is actually a good candidate if you don't want wheel spacers later. They are the same width as the front ends under our trucks instead of a couple of inches narrower. Perch width and shock mounts would more than likely need changing but thats cake...
    Rene
  5. Grim-Reaper
    7,385
    Atlanta
    I would say that your much more likly to break everything else in the driveline before you break a 14. Most of the time your drive shaft U-joints or drive shaft wil become the "Fuse". It's 600lb of love. That said it's still possible to break one given the right chain of events. Axle shafts take a lot of twisting and given enough cycles at a high enough load the can fracture but rarely will you see it happen.
    Most people feel a 14 ff is more compairable to the strenght of a Dana 70.
    It's not my damn planet monkey boy!
    <a target="_blank" href=http://communities.msn.com/OffroadK5s>communities.msn.com/OffroadK5s</a>
    75 Jimmy, Dollar
    79 Chevy Blazer, Her's
    70 Chevy Burb
    Grim-Reaper
  6. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I have never seen one broken but I have seen the axle shafts twisted 3/4 of a round on a mud bogger running a strong Big block with nitrous but the still did not break only twisted. Unless you run 44's and like to dump the clutch at 6000 then they are basically indestructable
    I thought I was wrong once,
    but I was mistaken
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I once saw a Dana 80 with a lincoln locker break in a pulling truck while pulling the sled.
    I'm pretty sure for your use the only way to break it is to drain the oil and beat it up real bad.
    Tim
  8. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    I guess that guy should used one your 10 bolts...then he wouldn't have broke a thing right? [​IMG]
    Rene
  9. SlyDog
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Thanks rene [​IMG]
  10. tRustyK5
    Jul 23, 2000
    36,184
    1,391
    E-town baby!
    No prob..."Cheap Shots 'R' Us" today [​IMG]
    Rene
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I talked to a guy in our club who has a pickup (well, it actually has an S-10 Blazer body now) running 42" swampers and a healthy 454. He's broke pretty much everything else on the truck, including front Dana 60 stub shafts (now has 35 spline stubs) and several 208 transfer cases. The only things he has never broken are the 205 t-case and the 14 bolt rear. This guy likes to do 4 wheel burnouts on pavement every once in a while.........
  12. californiak5
    californiak5 1/2 ton status
    Oct 25, 2000
    820
    Oceanside, Ca. 92056
    The guy with the D80 definitly should have went 1/2 ton HaHaHaHa [​IMG]
    See Ya,
    Keith
    [​IMG] <font color=green>Born to Drive My K5</font color=green> [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/californiak5>CaliforniaK5's Pictures</a>
  13. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Damn it Rene, you beat me to it! :D
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  14. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I've seen two 14FF's broken in my life - one was on a service truck that got ran over by a HaulPak 240E mine truck, the other was on a ambulance chassis - the left hand tube seperated from the carrier housing.
    Dos mas Tecates!!!
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  15. Brians 60s
    Brians 60s 1/2 ton status
    Jun 12, 2000
    1,115
    Bend, Oregon
    14 bolts are usually bulletproof. If one does break 9 times out of 10 it will be the spiders, if it is open. I have seen 1 axle shaft break with 44 boggers and a built cad 500 though.
    IT'S A 1 TON THING.... IF I HAVE TO EXPLAIN IT, YOU WOULDN'T UNDERSTAND!!!
  16. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I have a SBC 350 with a Doubler for a crawl ratio of 132:1. I have broke two axle shafts at the hub flange end and I was not "getting" on the throttle when it happened-just rocky trails. I've since ordered a set of axle shafts from Dutchman Motorsports and I've not had any problems for 6 years. My truck weighs 7500-that might have something to do with it-but I've seen other people break 14 bolt shafts on extreme trailsw/44" tires too
  17. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    132:1?!?!? That is a SILLY crawl ratio! awesome!! =D
    J
  18. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    There are a few over at my buddies place that are trashed. One got ripped apart in a pulling truck. I think a 750hp bigblock might have had something to do with that,[​IMG] Most of them though are tore up because of no gear lube in them.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You guys are taking this to an extreme. A pulling truck is far different than putting a truck in the mud. Pulling trucks have weight added for extra traction and huge motors (that one had a 530 cubic inch BBC in it ).
    I didn't say 10 bolt fronts and D44s were the greatest thing ever, but they are quite strong (stronger than any Jeep or really quite a few other off road vehicles came with).
    His stuff (Dana 60/Dana 80) came from an early '80s 1 ton Dodge.
    Tim
