possible to get K5 to not sag?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dyeager535, Mar 14, 2001.
  1. dyeager535
    26,979
    My truck sags quite a bit in the rear. Imagine that. I talked to a guy locally, and he said bring the truck down, tell him how I want it to sit, and for $275, he will re-arch the springs, add a leaf, all to my height specs.
    My problem is that it is kind of hard to tell exactly how high the rear should sit to be level with the front. Does anyone know if the wheel well openings front and rear SHOULD be the same height to the ground if the truck sits level? I was thinking of just jacking up the rear of the truck until it looked level, then measure the wheel well opening to ground height, but thats almost like guessing.
    I'm thinking that when I have him do it, have the truck half full of gas, otherwise, the truck would end up jacked up in the rear end when close to empty, or sagging excessively when I filled it up. Any thoughts, ideas, specs?
    Dorian
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    You can get new springs cheaper than that... Just ann a add-a-leaf... 2 incher will do nicely...
    Um... yes officer I know it's too big...
  3. Innerpiece
    Innerpiece 1/2 ton status
    Feb 22, 2001
    145
    Mississippi (Yee Haw)
    The amount of gas shouldn't make that much of a difference ... unless your suspension is that shot (which it shouldn't be after everyhting is all said and done). I think jacking up the rear axle until it looks right is a great idea ... look at the ride height string ... jack it up from the frame and measure from the rear axle to the frame ... you'll end up with something that you like ... my 87 silverado, that I think is stock (except for 32" tires instead of 31"), sits a little nose low ... I think it look's mean and angry (good for a big ass truck)
    FWIW
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    Two things I do know;
    1) Re-arched springs will lose there arch quicker than new springs.
    2) The wheelwell openings are different heights. However the body line above the fenderwells on the 81 and newer trucks is a good indicator of level.
    Have you thought about the '0' spring rate 1" add-a-leafs from ORD? I guarantee those won't sag again in a year.
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  5. dyeager535
    26,979
    Gonna head over to that forum and ask the same question...I'd really rather replace all the leaves, I have heard the add a leaves are a pain in the a$$ to put on.
    Dorian
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Add-a-leaves aren't too hard to install. You don't even have to remove the spring packs from the truck.
    Once you have the axle unbolted, just C-clamp the springs to keep them contained, then remove the center pin.
    Loosen the clamp to slowly release the energy in the springs.
    Slip the new leaf in place and install a new center pin.
    Clamp the spring pack together with the C-clamp and tighten the center pin and cut it to length.
    Bolt the axles back to the springs.
    I did both sides on my S-10 in a couple of hours.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Not "add-a-leafs", he's talking about "zero-rate" leafs. I wouldn't use the AALs but the ZRL are fine. Check them out at ORD.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  8. dyeager535
    26,979
    Am I blind? i checked out their page and didn't notice anything there for "zero rate" springs. Got a link?
    Dorian
  9. rocko
    rocko 1/2 ton status
    Jul 3, 2000
    3,380
    Ellsworth, Maine
    Hey Dorian... You might just want to consider a 2.5 inch lift kit w/ front and rear springs.. my truck sits nice and level now .. no sagging.. I installed Rough Country's lift kit.. and the 2.5 inch kit doesn't cost that much.. and talk about a nice ride...
    Experience is something you don't get until just after you need it. <A target="_blank" HREF=http://www.rocko.coloradok5.com>http://www.rocko.coloradok5.com</A>
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
  11. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    That's interesting, I thought he had them on the site now. Oh well, rusty got you the link at CK5. What I think of as "add-a-leafs" are the high arch things that preload you spring pack to give you lift and make it ride like crapt. These "zero-rate" leafs are really just spacers bolted into the spring pack just like another leaf. They don't have the drawbacks of blocks or add-a-leafs and are perfect for fine tuning your lift.
    Bad Dog
  12. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    I got my add-a-leaf from 4 wheel parts wholesalers about 4 or 5 years ago. My rear end sits just a little higher than the front which I think looks good. They haven't sagged at all and my ride isn't much different than stock. They weren't that expensive either.
    Esteban
  13. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    How much does it sag in the rear. Jack it up and measure how much higher you would want it and buy a small lift block from AutoZone, Pep Boys, etc and stick it down there. A samll one won't really affect axle hop like a big one would, and it should only cost about 10-15 bucks
    90K5
  14. kenbrown
    kenbrown Registered Member
    Feb 9, 2001
    20
    Utah USA
    i have 4" super lift springs all around and a 2" block in the rear and if you measure to the body line its close to level. u can see mine in readers rides. its the blue ox. i think the photo i have there now would be hard to see the levelness (is that a word?) if you want to see it ill e-mail u a photo. just give me the word.
    about the rearc mine died around a year and it looked goofy as hell cuz it sagged all sorts of different ways. and it cornerd like crap. i sure love the new springs.
    ken
  15. dyeager535
    26,979
    Your not the one that took me for $10 are you?
    Dorian
  16. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    I have 2.5 Procomp lift springs in front,and a 2 inch block,and 1.5 inch add-a-leaves in the rear and it sits perfect..!!
    <font color=blue> Yesterday was history,today is a mystery,and today is a gift. -Taproot- </font color=blue>
  17. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    One other way to "level" it out................add a large winch up front! Dropped my front 3/4 of an inch...............LOL.
    <font color=orange>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;<A target="_blank" HREF=http://www.blazzinor.coloradok5.com>http://www.blazzinor.coloradok5.com</A>
