Possible to have a 4L80E doubler?
Discussion in 'OffRoad Design' started by Sledge, Nov 9, 2001.
  1. Sledge
    Sledge Registered Member
    Feb 24, 2000
    75
    Reno, NV
    I'm building a '72 Jimmy in which I was planning to mate a 4L80E to a NP205. Since I'm going to be playing the specialty adapter game anyway, I was wondering if it was posible (w/o spending the earth) to use a Doubler to mate the tranny and t-case(s). Anyone know if this is feasible, and how it might be done? (Machine a TH400-203 adaptor?)
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    In a '72 K5, you may want to look into what you would have to do to get a 1 3/8" output shaft in the 4L80, then use the 1 1/8" factory TH400 to NP203 adapter plate. If you can spare another 1.5" or so, you could use the factory 4wd adapter housing and drill and tap the bolt pattern into the front face of the NP203 and bolt it directly together. This latter method is going to be the cheapest and easiest, but does cost a little length.
    Making the world better, one truck at a time.
    SW-ORD
    <a target="_blank" href=http://www.offroaddesign.com>www.offroaddesign.com</a>
  3. Sledge
    Feb 24, 2000
    75
    Reno, NV
    Stephen, can you elaborate on the second option? I'm planning on using one of your shackle flips and a CV driveshaft in the rear so I doubt that an extra 1.5" of length will mess up the angles too badly. When you say "use the factory 4wd adaptor housing..." which housing are you refering to? Do you mean a tranny to t-case adaptor, or something else. Sorry if I'm being dense here. I appreciate you taking the time to spitball ideas here on the board.
  4. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    The factory 4L80 to 241 adapter is about 2.5" thick and has a round pattern at the back that's easily matched up to the NP203. The shaft stickouts work out well with that technique, and the parts are readily available. Basically all you have to do is install a 32 spline input gear in the NP203 and re-drill the face of the 203 case to take the round bolt pattern.
    SW-ORD
  5. ccj8008
    ccj8008 1/2 ton status
    Apr 2, 2001
    228
    Polson MT
    My 91 1 ton Silverado has a 4L80E mated to an NP205. This was the factory set up.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Are you sure it's not a TH 400? I didn't think 4L80E's came around until about '93?
    Tim
  7. ccj8008
    Apr 2, 2001
    228
    Polson MT
    Positive. 1991 was the first year that I know of that the 4L80E was used. Unfortunately, this was also the last year for the Dana 60 front end.
  8. Sledge
    Feb 24, 2000
    75
    Reno, NV
    Thanks for the info, I also thought the 4L80 debuted in '93. I wonder if I could find a NP205 and adaptor at a bone-yard and skip the Advanced Adaptors custom stuff. Worth a look anyway.
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I don't think you need Advance for anything that has to do with factory parts, the factory put this together at some point so we can use factory parts to do it again.
    SW-ORD
  10. Sledge
    Feb 24, 2000
    75
    Reno, NV
    You're right, of course, Stephen. I got some bad info regarding the starting year of the tranny. It should always be cheaper to use factory parts than go custom. Looks like I'll be calling the j'yards. :)
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Depending on what you're looking for the wrecking yards may not be a good place to find it, but when you start looking at spending $500 on adapters, you can buy new or old stock factory stuff pretty easily.
    SW-ORD
  12. Sledge
    Feb 24, 2000
    75
    Reno, NV
    Where would you recommend, if not a wrecking yard? Any advice is appreciated.
  13. Sledge
    Feb 24, 2000
    75
    Reno, NV
    Duh, I didn't read you post very well. New old stock. That's how I got the '98 tranny I'm trying to use.
  14. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Measure the output shaft stickout and call us and we'll see what we can do. I'm guessing the best way to do this is with a standard GM 4" adapter and the long input in the NP205. We'll see.
    SW-ORD
