Possible to knock dent out of door from inside?
Discussion in 'The Garage' started by 84k5, Dec 1, 2002.
  1. 84k5
    84k5 1/2 ton status
    May 13, 2000
    2,949
    Dublin, CA
    I went home for thanksgiving and on friday me and dad took the k5 out to the desert for some wheelin. Wheeled all day, had a great time, didn't put a mark in the truck.
    Saterday night I take the girlfriend out for dinner and stuff. We get back and as she's getting out I lock the doors as always. Well she didn't shut it hard enough (never does) so she gives it a good wack from the hips. She got it shut, but put a dent about a foot across in it. I have no idea where the power to do that came from as she is pretty small??? /forums/images/graemlins/confused.gif
    Anyways...I was wondering if I rip all the stuff off the inside of the door will I be close enough to sheet metal to just push it out? I've never taken a door apart before. It's an 84 w/ power windows.
    Please help..it is very embarrassing to tell people the huge dent in the door is from your girlfriends ass. /forums/images/graemlins/ignore.gif
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Yeah...those dents come right out and rarely leave any 'scars' behind. Take the door panel off and see what you can see...most likely you'll be able to clearly see the reverse impression of the dent through one of the access holes in the door. Next step is to push it out with the palm of your hand, or if it's a bit stubborn a deflated basketball can be used. Insert ball and begin inflating til the dent pops out...deflate and remove. (credit where credit is due...the deflated ball idea is Grim Reapers)
    Rene
  3. TheBlazerKid
    TheBlazerKid 1/2 ton status
    Apr 26, 2000
    259
    Raymond, Washington
    If it is a smooth dent with no creaces (sp?) then you might be able to plunger it out, and if not then yeah you oughta be able to wack it out from teh inside, depending on where it is in the door you might be able to just rooll the window up and get to it with the door panel off. try just pushing on it with your hand. and if that wont do it use a 2x4 with a hammer and just hit it hard enough to get it out. we did this to my buddy-s 74 when i slid into it in the mud. oops. hehe well hope that helps!
    Nathan
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    just use a plunger. s=tick it to it and get a suction then pull.
    nathan
  5. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Having done this many times to 3 different trucks first try your palm...pop the panel off, I even rotate the mirror on that door to the dent so I can see what I am doing, apply pressure and it should pop right out, a plunger will more than likely scar the paint if you have a nice paint job consider that, the 2x4 will leave 2x4 outward scars visible on the outside.....trust me, made that wistake before. Its very easy, give it a shot.
  6. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have used a plunger many times even on small dents. you can bearly see the dent just a ring where you put the plunger, which wipes away. just make sure its clean. you don't want a spot of "mud" that stinks. LOL
  7. Jeremy_C
    Jeremy_C 1/2 ton status
    Mar 26, 2002
    1,381
    East TN
    that deflated basket ball idea is pretty slick. I'll have to kick a dent in my door so i can try that. /forums/images/graemlins/grin.gif /forums/images/graemlins/truck.gif
  8. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    i've done the same thing to my drivers door. i just slammed the door getting in the truck and it popped out on its own. /forums/images/graemlins/thumb.gif
  9. Grim-Reaper
    7,385
    Atlanta
    Works good on rear quarters also. /forums/images/graemlins/thumb.gif
