Possible to wire headlights into a toggle switch?
Discussion in 'The Garage' started by zakk, Feb 23, 2003.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Hi all,
    I recently ripped out the dash and the only casualty was the headlight "pull-thingie" (i think that is its scientific name)
    I want to get all the switches up out of the way...has anyone run this into a toggle switch? All i want is ON/OFF, i have no desire for parking lights, dimmer switches or courtesy lights.
    any ideas, thoughts, or outright lies are apprecaited! /forums/images/graemlins/grin.gif
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    did it on a 78 olds. it worked the toggle i had got a little hot cause it was metal nothing serious just warm . worked fine i d still fix it right if i could hope this helps
  3. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I wired my street mostly legal Dune Buggy's headlights with two milspec toggles. One is lights on/off (SPST), the other is hi-lo(SPDT).
  4. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I don't see why you couldn't do that pretty easily.
    What about the hi-beams? You wouldn't want to have low beams for street and hi beams for like pismo at night!? /forums/images/graemlins/confused.gif /forums/images/graemlins/grin.gif
    /forums/images/graemlins/k5.gif
  5. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    Zakk,
    You would need to use a relay. Most toggle switches aren't designed to handle the amperage of your light system. Use a toggle switch the turn a relay on and off to power your lights.
    Mike
  6. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    no, I'll just watch you fall off the face of the earth again /forums/images/graemlins/rotfl.gif /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Zakk,
    Mike
    interesting. do you have a pic or a discription of how i could run this? (i'm an electrical idiot/forums/images/graemlins/crazy.gif )
  8. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Zakk, good thing for you that I am close and can show you how to do this using relays. I have several relays wired to switches for various things on my rig.
  9. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    good thing for me indeed! thanks Scott!
  10. bigjbear
    Feb 18, 2000
    13,966
    448
    Marietta GA
    Radio Shack has 30 amp togle switches. Think that's enough for the head lts? I'm not sure what the power draw is. A relay would be better though.
    BTW, I'm running that 30 amp sw for my wipers and a seperate momentary for the squiters. Motor and sw were both bad and I used a newer motor and all the plugs were different so thats why I went the togle sw route.
