Possible use for line locks, 14FF with discs
Discussion in 'The Garage' started by steelsoldiers, Feb 6, 2003.
  1. steelsoldiers
    steelsoldiers 1/2 ton status
    Oct 17, 2002
    365
    Charleston, West Virginia
    Hey y'all,
    I was flipping through a 4-wheeler mag last night and noticed that Toby Harrel's blazer /forums/images/graemlins/grin.gif had two line locks mounted on top of his 14FF. He's not running disc brakes, but I thought that would be a good solution for an e-brake. The line lock I was looking at is button activated so that you step on the pedal, push the button, release the pedal, and you are locked up. So, I'm guessing you could leave it like that until you get back in your rig an step on the pedal again to release it, or do you have to have juice running to it to keep it locked /forums/images/graemlins/confused.gif? I know they are supposed to be used for racing and not as an e-brake, but it would be great for short term braking. Anybody doing this, and do they continue to lock with the truck power off? Thanks.
    Chris /forums/images/graemlins/k5.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I, too, would like to know some info about this. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
    Hmmm, I was thinking about this, and I don't think it would work for my intended purposes. What I wanted to do was instead of hooking up the mechanical e-brake when I swap in 3/4 ton axles - I would consider getting a line lock. (In Wisconsin, you must have a functional e-brake on your vehicle) And, now that I think about it, I doubt that could be categorized as an e-brake. Say if your master cylinder or something else went out - you'd have no way of creating pressure for the line lock. So, it would work well as a parking brake - but not good for an e-brake. (also not good for an e-brake because either it's off, or on - tires would lock up or roll). So, I guess that's no longer an option for me.
  3. steelsoldiers
    Oct 17, 2002
    365
    Would a 44" Bogger with a chain hooked between it and your bumper classify as an e-brake. You could make a break-away tire carrier and have a lever beside your seat to release it! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  4. heavy4x4
    Aug 28, 2002
    3,270
    E-brake: maybe
    But I think the cops would nail me as a danger to others! Just imagine a 44" bogger bouncing/dragging in front of the car behind you /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  5. Emmettology 101
    May 9, 2000
    8,126
    FL
    People have been using these as e-brake for a long time! Although they bleed off over a period of time so you couldn't use it to hold the rig over night....
    You could either go with a Mico-Lock or a cheapo from JEgs, summit or JC Whitney.........
  6. steelsoldiers
    Oct 17, 2002
    365
    Thanks Mike,
    Do you have to keep the power flowing to them to keep them locked like a solenoid?
  7. Emmettology 101
    May 9, 2000
    8,126
    FL
    That I am not sure. I have never used one personally, but have seen people on the net and mags using them. I have checked into some, but never looked into it in that much detail.
    I know the Mico lock is around $250 though!
  8. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    Wheeled with bunch from S.Carolina at Tellico who used line locks on their Jeeps.They work well,will bleed off though.Said if left on to long solonoids would burn up.Have a friend with Lever locks that work good.Have to run line inside truck to use them.Just step on brake and flip lever,holds till released or like said will bleed off over couple of hours. He has one for each axle /forums/images/graemlins/thumb.gif
  9. jekbrown
    May 19, 2001
    45,029
    362
    Vancouver, WA, USA
    how much do these things generally cost? i wouldnt mind running brake lines into the cab so long as the things worked.
    j
  10. steelsoldiers
    Oct 17, 2002
    365
    Heavy4x4, I just talked to the fellas at A-tron and they told me that they are working on a e-brake kit for their 14FF disc kit. It should be out in a month or so. It works in conjunction with the stock e-brake system /forums/images/graemlins/grin.gif. That should get you to pass inspection easily and get a functional parking/e-brake to boot. It sounds a lot simpler that running line lock, especially if they bleed off over time /forums/images/graemlins/eek.gif.
    Sincerely,
  11. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    Check your local laws. I know in New York that you CAN NOT use them as a parking/emergency brake. That brake system MUST be a MECHAINCAL back up system. It cannot be combined with the regular brake system. I plan on using a mechanical e brake on the back of my 205 case. High angle has a kit. The Line lock selonoids are also NOT designed for long term power use. They will burn out. I have seen people use line locks on trail trucks to turn tighter. By locking one tire, It will make truck pivot tighter. I don't know why that guy had them on his truck though.
  12. heavy4x4
    Aug 28, 2002
    3,270
    Hey thanks....I'll look into it when the time comes /forums/images/graemlins/laugh.gif
  13. 45acpJr
    45acpJr 1/2 ton status Premium Member
    Jan 7, 2003
    632
    Tucson, Az
    As soon as they are ready we will let our fellow CK5 members know /forums/images/graemlins/thumb.gif
