Possibly the dumbest trannsmission thing I've ever done!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Bowtied, Aug 15, 2002.
  1. Bowtied
    Bowtied Registered Member
    May 21, 2001
    69
    NC
    Possibly the dumbest trannsmission thing I\'ve ever done!
    Okay, i made a post just a few days ago and asked questions regaurding my tranny slipping (more like bucking) from a dead stop. Well, today I was flying down the road and came to a stop, when I went to leave the stop, my truck shook like I was running over a huge wash board. I stopped and chaecked the fluid level expecting to not find a drop on the stick but it was actually a few inches above the full line! So, my question is, if the tranny is grossly overserviced, would it cause my problems?
    I am going to try to drain some out and try it that way but please let me know what you all think...
    Thanks!
    Bowtied
  2. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,084
    486
    Grand Rapids area
    Re: Possibly the dumbest trannsmission thing I\'ve ever done!
    Over filled can cause some strange operation. Sometimes it decides to purge and blows out your front seal (pull the tranny and X-case back to fix) or shoots up the dipstick tube (engine fire if it hits hot manifolds), but hopefully squirts out of the vent on top (messy road and smoking exhast pipes).
    Just take some fluid out and see if that fixes it.
  3. Jay73K20
    Jay73K20 Registered Member
    Mar 4, 2002
    67
    When I had an overfilled 700r4 tranny if wouldn't shift out of first and blew out the vent tube. It caught on fire on my headers. Drain it fast!!
  4. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    It will severely effect your shifting as the valve body is completely immersed in tranny fluid. It delays the movement of the valves and venting of fluid during shifts. And that is the beginning of the problems!
  5. Grim-Reaper
    7,385
    Atlanta
    Well did you check it with it running or was it it off? got to check them while the engine is on. The coverter will drain back into the pan and give you an incorrect reading when they are off.
    If it is over filled then ris it might be causeing the problem. Stuff in the valve body has to drain to work right..if the level is above the drain then it might cause problems. Also if it way to hight the drums and rotating mass is in the fluid and could be ariating. If airrated fluid got sucked up by the pump then it's possible that it would start slipping because...AIR compresses MUCH more then fliud....If it's over full get that pup back down to the right level and see how it does.
  6. Grim-Reaper
    7,385
    Atlanta
    You know what.....Surfing while working a repair shop suxs caus it takes me 30 minutes to type three lines between customers! LOL.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    <font color="green"> Dude! I wish i could surf between coustomers /forums/images/icons/cool.gif </font color>
  8. Bowtied
    May 21, 2001
    69
    NC
    Alright guys, thanks for the info
    I'm going to de-service it a little tommorrow and hope that all is well and no damage has been done.
    Thanks again for your help.
    Bowtied
  9. dawson444
    dawson444 1/2 ton status
    Jul 5, 2000
    1,034
    Raleigh, NC
    Yea if it comes out the vent tube it can get on the exhaust pipes and catch on fire. I know from experience.
  10. Bowtied
    May 21, 2001
    69
    NC
    Well, I drained out the excess fluid today and filled to the exact amount and it's still acting up! I can't figure it out, it acts like it doesnt go into gear until you give it a little throttle but once it engages it'll still spin the tires...
    I was wondering if the valve body was bad or maybe even the modulator. I was told that it could be the bands. That sounds expensive!
    Thanks for your help,
    Bowtied
  11. DuneRunner
    DuneRunner 1/2 ton status
    Aug 1, 2001
    1,252
    Fremont CA
    B&amp;M makes a band tightener. I've talked to peeps that have used it and said it works wonders. TO drag out the last of life of the tranny. Hope this works...I'm experiencing something like this as well. /forums/images/icons/frown.gif
  12. Bowtied
    May 21, 2001
    69
    NC
    DuneRunner,
    Thanks for the info. I took my truck to a tranny shop today and just as you can imagine, it acted fine the whole stinkin time! The Manager and I rode around beatin on it for about 15 minutes and it did fine. Of course then on the way home it started acting up again. I don't know a lot about tranny's but I am starting to think it is a pressure problem. Once it's good and hot it will act like it is almost popping out of gear but only at idle. If I romp the gas it'll grap real hard and go. As a matter of fact, when I got in my drive way this evening I sat there at idle with the tranny in drive and it felt like I was shifting from D to N and back and forth. Constantly engaging and disengaging yet I never moved the shifter the entire time!
    Hey, if anyone out there has any insight on this one I would greatly appreciate any help at all!
    Thanks all,
    Bowtied
  13. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    Did u checked if the filter is pluged??
    Or if the gasket between the filter and the valve body is there??
    Sure u gona have to take the pan out but it is simpler then to pull the trany out to be rebuild!!!
  14. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Drain it fast man. This is what happened to my friends truck on a club run when his tranny boiled over. Not a good thing to have happen in the middle of nowhere.
    Lil' Bitty Burb Up
    Brian
    82 burb
    38.5's
