Post Crossover Steering Install Concern...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Waxer, Jun 17, 2002.
  1. Waxer
    Waxer 1/2 ton status Author
    1,857
    Long Beach, CA.
    I finished my crossover a good couple months ago or so and one thing noticed was that I do NOT have lock to lock steering. I swapped in a 2wd output shaft into my existing 4wd box. The steering when going left to right actually gets stopped like I'm hitting the stops on the axle but when I look I'm a good 1/2" to 1" away from the stops. Anyone have any similar experiences or know what might be causing this? Perhaps I got the wrong output shaft and its physically hitting the inner walls of the box and being stopped by that? The gears looked the same when compared to my 4wd shaft. Hmmmm.
    Any help would be appreciated.
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Maybe a longer pitman arm would help?
    Rene
  3. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    Jack up your front end and try it. Front tires off the ground. I had this problem with a dropped draglink. A non rotating tire has a lot of friction. The bigger the tire, the more friction. In my case it was easier for the steering linkage to extend the suspension (push one corner of the truck up) there by extending the steering linkage instead of turning the tire. This goes away when the truick is moving. Let me know if this is the case with yours.
    Eric M.
  4. Mudzer
    Mudzer 1/2 ton status Author
    3,639
    Missouri
    Rene has a valid point. TheBigdaddyof2 did the same swap without problems. I beleieve he used the Superlift arm (like me and others). Mine actually hits the bumpstops and moves the whole frontend over a bit because the box still allows some travel. Kind of a wierd feeling. Now, I have a delima with my crossover. My truck squats some on the right side when the steering is centered (wheels). I have turned the wheels left and right and let it rest at full turn and the body actually sits different thruought the steering arc. So, do I need to adjust my draglink to fix this problem? Anyone have this issue with crossover? I call it the Weeble affect since we have Wobble already. /forums/images/icons/smirk.gif
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    I'm fairly sure that's just an effect of the caster built into the front end Neil. My Jimmy does that with stock/forums/images/icons/blush.gif front to back steering.
    Rene
  6. 85m1009
    85m1009 1/2 ton status
    Jul 11, 2000
    718
    Missouri
    If you jack your front end off the ground and cycle the steering you should have 3 1/4 to 3 1/2 turns lock to lock. If that checks out then you have the ratio problem that Rene was talking about. You either need a longer center to center pitman arm or a shorter steering arm on the knuckle.
  7. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    You've got the Avalanche arms ritght? Maybe the drag link is one hole too far out?
  8. UNCLE CRACKER
    UNCLE CRACKER 1/2 ton status
    Dec 29, 2001
    937
    PORTLAND OR
    I had the same problem. I found that my drag link was to short. I got a longer one and it cured the problem.
  9. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    Weeble - Wobble ....that's hilarious!
    Thankfully, I haven't fell down yet.
    Actually, I used the Trailmaster pitman arm and a Tri- County steering arm. Mine hits the stops on the D44 before the box runs out of stroke.
