post lift kit woes
Discussion in 'The Garage' started by KohlTrain, Aug 8, 2005.
  1. KohlTrain
    KohlTrain Registered Member Premium Member
    Aug 8, 2005
    89
    Ione, Ca
    I have just finished with skyjacker 4" w/rear leaf kit. Its an 87 full size jimmy. Truck was perfect when I pulled it in my shop. Now with the system installed I have a mean vibration at all speeds and sometimes a grinding noise at higher speeds. The grinding is especially loud if I throw the auto in neutral while rollin at 55 mph. I have had the driveline out and the universals are tight and lubed. What the heck? Any suggestions? I haven't lowered anything because all the tech line guys said is not neccesary for only 4" lift. Any suggestions greatly apprecitated, I can not figure this one out. Should I change the universals anyway? :mad:
  2. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    is the front driveshaft rubbin the crossmember or exhaust?
  3. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    maybe the rear spring shims are backwards forcing the rear joint angel worse instead of better?
  4. KohlTrain
    Aug 8, 2005
    89
    Ione, Ca
    I have the thick end of the rear leaf spring shims facing the rear like the instructions stated and the front drive is not binding or touching the exhaust.
  5. perp
    perp 1/2 ton status
    Jul 14, 2005
    569
    Chandler AZ
    is the rear d shaft a slip yolk or a bolt yolk?
    if it is a bolt yolk ( with slip spline in center of shaft ) did you maybe take the two havles of the shaft apart and re-assemble out of phase
  6. Stoner42
    Stoner42 Registered Member
    Jul 17, 2005
    15
    Williston ND
    Are the u-joints new? Its possible that they wore in one spot and now that the drivelines at a different angle its cycling from the worn spot to an unworn spot as the shaft rotates.
  7. crowley
    crowley Registered Member
    Oct 26, 2003
    24
    Phoenix, Az
    lower your trans/ t-case crossmember!!! the spacers are already provided! there on the top side of the lower frame rail, spacing the nut away from the inside of the frame. install those spacers between the bottom of the frame and the top of the crossmember, tighten the bolts up, it should take care of your problem.
    please use a floor jack, and only do one side at a time!
  8. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i have the grinding noise on my k5, but its with about 9" of lift. its because my driveshaft angle is real bad. you cant really hear it when u have the pedal down, but when coasting it sounds really bad. it also vibrates a bunch. so HAD driveshaft is in the future
  9. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    Dont Use Those "spacers"
    those "spacers" will punch some nice holes in your crossmember and render it useless if you get into any sort of flexy situation or hit anything... they redistribute any "twist-load" of the crossmember into those 2 tiny circles rather than the large flat surface and pull right through
    do it right and buy some flat steel and cut it to fit (i used 1/4" steel bar from the local hardware store and drilled 2 holes for the bolts and good to go)
  10. csnutrition
    csnutrition Registered Member
    Jan 8, 2003
    16
    North Alabama
    I had a similar problem with vibration after installing a 4" on 76 Blazer. I kinda thought it was something I was going to be stuck with. Luckily the shims Rough Country provides with there lift kits suck and mine shattered . This forced me buying new shims, for which I purchased 6 degree shims. Problem solved. Matter of fact this past Friday I purchased a set of BFG/replacing the TSL Bias and now I have virtually no vibration. Bottom line...get that drive line at the proper angle and you will solve your vibration problem caused by the lift kit
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Well , they make shims ( I don't really like )
    You can reweld perches ( best , but we all can't do , ask a friend if you can't )
    And for those of us with flips , or shimmed up , theres CV's .
    If you do a all spring lift , yokes need to equal , yet opposite in angle .
    If you do shackle flip , pinion points at transfercase and you run CV .
  12. KohlTrain
    Aug 8, 2005
    89
    Ione, Ca
    Thanks for the advice. Have the next couple of days off will try to get it smoothed out by then. The vibration is so bad I can hardly stand to drive it. One good thing is the new suspension w/the nitro 8000 ( all i could afford after buying the new leaf kit) shocks rides better than it did stock! Man that old stuff must have really been worn out.
  13. wforicv
    wforicv 1/2 ton status
    Feb 16, 2004
    165
    Back in Augusta, GA again
    klink
    I say replace your ujoints first. When I installed my 4" lift I had the same problem. Replaced the rear ujoint and everything was nice and smooth. It is fairly safe to say you should be just fine with 4" but every truck and lift kit is different.
    Eroc
  14. KohlTrain
    Aug 8, 2005
    89
    Ione, Ca
    I installed a 30.00 t/case lowering kit. Came with some heavy duty steel spacers. Vibration is almost gone and no more grinding noise. Thanks for all the advice.
