Post your best mod's for under a $100 !
Discussion in 'The Garage' started by 88Silverado, May 25, 2003.
  1. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    Post your best mod\'s for under a $100 !
    It always seems I can only scrounge up a spare $25 to a $100 every couple of weeks or months for Blazer mods. Im willing to bet im not the only one. Sooooooooooo....Post your best mods for the money and lets see what we come up with. Please state if the mods are for 1st gen, 2nd gen or universal /forums/images/graemlins/thumb.gif
  2. bigjbear
    Feb 18, 2000
    13,973
    453
    Marietta GA
    Re: Post your best mod\'s for under a $100 !
    Fender triming, cost: saw blades & cut-off wheels
  3. florida4x4
    florida4x4 1/2 ton status
    Sep 9, 2002
    255
    Florida
    1st gen - single wire alternator
    Gut and jumper the voltage regulator so it still looks factory
  4. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    If I was just starting out, I'd invest in this stuff...
    (Universal)-
    Manual hubs
    CB radio
    Set of offroad lights
    Fire extinguisher and mounting brackets
    Tranny cooler
    Tow Strap
    Steering box brace
    Hi Lift
  5. VirginiaBulldog
    VirginiaBulldog Registered Member
    Mar 15, 2003
    74
    Virginia Beach, VA
    5 35x12.50 bfg at's on pacer rims for 75 dollars /forums/images/graemlins/grin.gif bought them off a lady whose son kept getting tickets for being too high /forums/images/graemlins/blush.gif other than that i'd say a set of chevy highbacks and the matching rear out of a 79 to replace the crappy low backs for $100 and th350/np205 combo for $100, good thing i already have the sm465/np203, all i need now is to figue if i want auto or manual to go with the soon to be doubler /forums/images/graemlins/grin.gif
  6. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    CB Radio -
    I don't know about your buddies, but around here if you're not on the CB you miss out on MOST of what's going on during a trail run.
    Fire Extinguisher -
    Not a sexy mod, but neither is watching your truck burn to the ground (or someone else's) because nobody wanted to spend the $$$. I've personally used one two times already.....(both on someone else's rig) the trucks would have been lost otherwise.
    Tow Strap -
    Don't be a weenie and expect everyone else to bring one for you to borrow! /forums/images/graemlins/grin.gif Get a BIG, STRONG one....when you get REALLY stuck you'll be glad you didn't cheap-out.
    High-Lift Jack-
    The single best thing you can carry with you, but it's useless unless you acutally have places on your truck that you can jack from (ask me how I know! /forums/images/graemlins/blush.gif) It can also be used as a winch, fender uncrusher, prybar, etc......
  7. 88Silverado
    Mar 13, 2003
    2,664
    Swaybar Disconnects
    F*rd Front Shock Towers & Shocks...
  8. chillywilly
    chillywilly Registered Member
    May 26, 2002
    70
    northern maine
    Junkyard dual electric fans from 95 up windstar.
  9. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    Hey, I should be the expert at this one... since I am soo cheap! /forums/images/graemlins/smile.gif
    Here goes:
    Ford shock towers- although the shocks cost me around 200.00
    'Zero Rate add a leaves'- I used 4 old overload springs I had sitting around, only 3/4" but cut em down and there ya go- Cost: $15.00 max.
    shackle flip- used the front hanger off the rear of a 2wd 1/2 ton truck- cost: $50.00 for the new bushings
    rear bumper- cut from a 8" chunk of channel I had laying around- cost: $20.00 for some cut off discs and welder wire
    front bumper- see above- check out the pics in my post in this forum from today
    front Dana44 and 14FF- paid $100.00 for a 3/4 truck, sold 300.00 worth of parts, kept the diffs and numerous other goodies- swap is happening soon- cost: made 200.00 towards the gears for it
    rear disc brakes- used backing plates, front calipers and rotors from a D44, cost me: $200.00 for new stuff including bolts.
    workin on a cheap version of a crossover steering setup.
    workin on a self made twin stick setup
    More to come!
    Mike
    Forgot my snorkel! Cost $40.00.
  10. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    New ujoints. /forums/images/graemlins/thumb.gif
  11. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    CK-5 winshield sticker...$9.00 including shipping..
    John
  12. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Bosch H4 halogen headlight conversion kit. You don't realize how poorly your sealed beams light up the road until you throw a set of the H4s into the grille.
    Safety wise it was by far the best $100 I ever spent!!! /forums/images/graemlins/thumb.gif
  13. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    CB Radio
    Took the swaybar OFF completely. it's useless if you have stiff springs
    Cut out chunk in pipe in front of mufflers, piece of pipe to slide over chunk, negating straight pipes- 8.99
    Push button starter/ Ignition I/O switch- more amps to starter, much easier. true, you can turn the truck on without the key, but you cannot take it out of park
    (i didn't know i couldn't get it out of park until the first night in the advance auto parking lot i turned the truck on and tried to take it out of park and it wouldn't move, i figured the hill i was on had put too much strain on the parking sprag and i tried with a friend for 45 minutes roling the truck up and back until it reached the other limit of the parking sprag then stomping the brake and trying to pull it out of park, and i almost broke the handle off when my friend yelled "you stupid bastard! the keys aren't in!!") - $25
    Off road lights - $27
    Strobe lights- actually, yes, i had to take someone to the hospital and the blue strobes got people out of my way FAST with the PA and i have no horn anymore, so it say get them, you may find yourself in that situation! $13 (more expensive if you want them to be visible during the day /forums/images/graemlins/grin.gif )
    Can of WD40/penetrating lube- duh
    Shackle flip- in the process.
  14. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    For $100 I was able to...
    build a engine crossmember, build new shackles and spring mounts for the front and bolt in 57" fords front and back.
    next mod would be my TBI, cost me $115(close enough to count)
    that included the heads, intake, TB, gas tank and lines.
    -Jeremy
  15. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    -Jeremy
    was that $100 for a ratchet, prybar and whatever other tools it may take to break into a truck, pop the hood and remove the engine?
  16. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    how about a free brochure on how to save your money, lol
    air filter, plugs, mufflers, take your cats off and say they broke off from last owner, uhm.......
    gym membershp, loose some pounds and thatll help a little :P
  17. purple76pearl
    purple76pearl 1/2 ton status
    Jan 13, 2003
    450
    missouri
    fender trimmin by far teh best for free, ( plasma cutter )
    ill tell ya the worst mod every
    i stripped my interior, and rhino lined it, i cant hear a damn thing its so loud in there, echos likea mo fo
  18. ChevyCaGal
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Buy some of that heat shield padding and that cheap roll carpet at Walmart and put it down up front. It'll help a lot and cost you about $40... /forums/images/graemlins/thumb.gif
  19. dhdescender
    dhdescender 1/2 ton status
    Aug 10, 2002
    628
    Qualicum Beach, British Columbia, Canada - Eh.
    Dana 60.
    Oh wait, that was 500 bucks...Canadian...thats about 100USD Right?!?! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Poor /forums/images/graemlins/usaflag.gif boyz can't find em for cheap.
  20. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Dana 60.
    Fawker /forums/images/graemlins/ignore.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/angryfire.gif
