Post your diff ground clearance
Discussion in 'The Garage' started by 85mudblazin, Apr 5, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I figured this would be a good thread to see what kind of clearance with what tires yall are getting under your diffs.
    Please post:
    axle type
    tire type and size
    rim size
    Ill start with my pro comp MT 35's mounted on 15x10 rims and a 10b front and a 14b that is shaved to the bottom bolt hole.
    In the front I have 10 1/2"
    In the rear I have 10"
    :D
  2. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    33x12.50-15 TSLs on 15x10s
    Shaved 10 bolts
    10"
    39.5x15-15 TSLs on 15x10s
    Shaved 10 bolt/12 bolt
    13.5"
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I have 35" MTR's mounted on 15x8" wheels. My truck is currently aired down to 14-15psi from last Sunday's trail run.
    10 bolt front: 10" clearence
    14bff rear : 9.5" clearence
    Harley
  4. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    front 12 3/4 D44 38-15 bogger 16.5/8.25
    rear 11 1/4 14bltFF 38-15 bogger 16.5/8.25
  5. mrk5
    Apr 20, 2004
    12,341
    1,047
    Northern Colorado
    37" MTRs, 15x8 wheels
    D44 Front
    10.5"
    12bolt Rear
    10.75"
    No shaving
  6. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    15x10's, 39.5 x 15's
    14 bolt shaved...11.5"
    D60 not shaved...11.75"
    Rene
  7. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    9.75"x16.5" 42" tsl
    10 bolt 13.75"
    14 bolt 13.25"
    No shaving.
  8. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    Currently I have 205/60R16's on 16x7 stock steel wheels on a 14 bolt FF, about 3" of clearance max, not shaved.
  9. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    hmmm, interesting.looks like the average is only a 1" difference between a 10b to a shaved 14b. i thought it would be more than that. ill check my clearances in the morning
  10. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    Ya, but the 14bf pumpkin is way wider then a 10 bolt pumpkin. That is a big part of the hanging up on the 14bff issue beside the lower ground clearence.
    Harley
  11. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    its dark ill post em tommorrow... ah what the hell give me five minutes.
    Hmmmmmmmmmmmmmmmmmmmmmmm... I think i just found a D60!!!
    went to measure the back 10b and got 10" then went to the front and got about 9 inches. 16x35x12.50 bigo M/T big foots
    one question... is the clearence of a d44 and a 10b the same? If it is i just found a d60 up front.
  12. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    It's usually 1.5" of difference between a 10 bolt and a 14 bolt. You figure it has to be at least 1" different because the ring gear is 2" bigger.
  13. Blazr77400
    Blazr77400 1/2 ton status
    Aug 31, 2001
    652
    Ogden, UTAH
    Unimog 404
    42" TSL
    16.5x8.25
    18.5" of clearance
  14. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
  15. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    not sure how much this is, those are 40's on one ton axles on 15.6 x 9.75
    about 25 psi
  16. 82K5_6.5L
    82K5_6.5L 1/2 ton status
    Dec 4, 2002
    439
    Tucson, Az
    35" BFG MT's on 15x10's
    10 bolt front- 10.5"
    Rear-12 bolt 10.75"
    :D
  17. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    35" MT/R's on 15X10's with 28 psi
    D44 = 11"
    14BFF = 9.5"
    Time to shave the 14BFF! :D
  18. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Front: D60/15x10/39.5" Iroks - 10.5"...no shave
    rear: 14B FF/15x10/39.5" Iroks - 11"...slight shave
  19. BIG STEVE
    BIG STEVE Registered Member
    Jul 23, 2002
    66
    thornton colorado
    36/10.50 buckshots
    11 inch front 10 bolt
    10 inch rear 6lug semi floating 14 bolt
    90 jimmy
  20. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    35" BFG AT's
    10.5" front (10B)
    9.75" Rear (14B SF)
