potato gun write up?
Discussion in 'The Lounge' started by surpip, Jan 14, 2005.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    potato gun write up? Pictures now dial up beware
    im puttin together what should be a kick ass launcher when im done, so should i do a photo write up?
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    do it!!
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Here's mine..
    Its 7' long total. Combustion chamber is 3 23" long pieces of 3.5" .069 tube section in half long way and welded back together. I had to fab up the reducer thingy by hand with a hammer. Barrel is 5.5' of 2" .049 tube beveled on the end for ease of spud loading. The end has a 2" threaded nipple welded in, with a 2" screw on cap. The ignitor is a flint lantern ignitor mounted in a hole on the side of the chamber. I've used starting fluid, hair spray and small shots of Propane for propellant. In order of effectiveness- Propane > Starting Fluid > Hair Spray. Propane is just cool too...It's the loudest, makes the largest flame at night and launches the spud furthest.
    Hehhe, try this for some entertainment. Get some of those chemlight/glow stick things. Hollow out a chamber in the spud for the chemlight and launch the spud at night...It's pretty damn cool to see a glowing green spud sent into orbit. :grin: Or you can load up a spud like usual, then dump a handfull of sand/rocks down the barrel. Cut the top off a couple of those glow sticks and pour the juice down the barrel. Do it at night and the bigger rocks and stuff make a nice green splatter mark on the ground in the shape of a cone....lol. The smaller dust particles make a glowing green cloud that floats away...looks like some kinda radioactive fart cloud. :D
  5. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,607
    601
    Hooper, Utah 84315
    If you build one use an electric valve like you would find in a sprinkler system the are ninty degree and work really well hook a nine volt to the valve and a switch use the design if the Sadar listed on that web site. Use a metal valve from a car/truck rim to get air into the tube and make sure you use sch. 40 pvc its good to like 200psi.
  6. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    :haha: :haha: :haha: :haha:
    Thats hilarious:D
  7. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    alright it's all put together, pic's to follow soon:D
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    horay!!!!:xmas:
  9. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Ok here it is:
    here are the parts i used, 4" threaded end cap, 4" threaded bushing end,4" cuppler 10" of 4" pipe(est. i eyeballed it)4"to 2" bushing, and 2"to 1 1/2" bushing, and 4' of 1 1/2" pipe for the barrel. Approx. price of pipe was 25 bucks.
    these are kind blurry but you get the idea, i sharpened the end of the barrel with a dremel tool.
  10. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    next
    The ignighter was a Webber cost from Home Depot was $9.99 I drilled a 1/2" hole in the 4" pipe and sanded it out a little bit sot hat the ignighter was a real tight fit. On my old one i used the pipe glue to put it in, and now its brokenand its going to be a bitch to get out, so this time i went with Hi Temp black rtv, should be eaiser to replace:D
    this puts the ignighter almost exactally in the center of the combustion chamber, and makes for no leaks at all.
  11. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    lastly
    here it is all put together, i just painted it so ill get pictures of that when its all dry:D
  12. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    SWEET! I'm gonna go blast mine off a few times this weekend, I'll pic whore some pics of it when I get back.
  13. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    mee to im takin it up to the snow:D
    die snowman die
  14. mofugly13
    Oct 6, 2002
    2,813
    San Francisco
    I use ether as a propellant. AWESOME! when you spray just the right amount.
  15. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    dale... buy my 37 mm and learn to reload the rounds... youll be much happier....
    just think of the forest fires you could start with some willie pete rounds!!!
    uh... I have those
    cam
  16. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    you know Cam, if i couldent get those ar-15's from you, somthing tells me the 37mm would be out of the question:D
  17. cbbr
    Jul 17, 2004
    14,681
    Ether works very well.
  18. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Ya i use starting fluid, cheaper than hairspray:D
  19. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    Holy crap we have a winner:D This thong is crazy loud, alot louder than my other launcher. And boy does it fling those potatoes, i shot it straight up, and lost sight of the patato:D :D Good times,
    ill be taking orders soon:p:
  20. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    ass soon as i figure out how to make the patotes explode, im going to say my patote gun is cooler than your 37mm,
    and alot cheaper per round too:D
