Potential or Newbie oxy-acetylene Torch owners. Please Read.
Discussion in 'The Tool Shed' started by RustyParts, Apr 6, 2006.
  1. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    OXYGEN ACETYLENE WELDING & CUTTING
    EQUIPMENT
    Introduction:
    The oxy-acetylene torch can be used for various tasks. It can be used for cutting steel, welding steel, brazing and for heating metal. The oxy-acetylene torch is a safe tool if used properly. However, if it is used incorrectly, serious injury can occur to you and the equipment. Understanding and utilizing the safety procedures are required to be able to operate this tool in the Metal shop. The main parts that make up the oxygen acetylene equipment are:
    • Cylinders
      • Oxygen
      • Acetylene
    • Regulators
    • Hoses
    • Welding attachment
    • Cutting attachment
    Oxygen acetylene welding is also commonly referred to as Oxy-Acetylene.
    CYLINDERS:
    The oxygen and acetylene cylinders are designed to hold high-pressure gases. There are some important things to remember when using these cylinders:
    • Cylinders must always be stood upright and be secured by a chain
    • When not in use (regulator mounted) they must always have a valve protection cap in place
    • Cylinders should be stored in a cool dry place away from direct sunlight or extreme cold
    Oxygen Cylinders
    · Usually red in colour, smaller in diameter and taller than Acetylene
    · 2200 PSI when full
    · The cylinder valve must be opened fully (double seated valve) or it could leak!
    · You should not run an oxygen tank below 50 PSI.
    Acetylene Cylinders
    · Usually black, large in diameter and short
    · 250 PSI when full
    · The cylinder valve should only be opened ¼ of a turn.
    · The acetylene cylinder should never be laid down as this will result in the gas becoming unstable.
    · You should not run an acetylene tank below 50 PSI.
    HOSES:
    The oxy acetylene welding hoses are made out of a durable rubber that is designed to withstand different pressures. There are several things to remember about the hoses:
    · Red = Fuel
    · Green = Oxygen
    · Do not kink hoses
    · Keep hoses away from work area
    · Wrap hoses when not in use
    · Keep hoses away from sparks and hot metal
    Hose fittings
    · Acetylene fitting are notched
    · Acetylene fittings are left hand thread
    · Oxygen fittings are smooth
    · Oxygen fittings are right hand thread
    · Both tanks should always be fitted with anti flash back arrestors
    PRESSURE REGULATORS:
    The pressure regulators enable the user to reduce the high pressure contained in the cylinder to a usable working pressure. There are several handling and set up procedures that are important to the overall operation of the pressure regulator. The pressure regulator on each tank shows two things:
    • Cylinder pressure (How much gas is in the cylinder)
    • Working or line pressure
    Installing the regulators
    · Before installing the regulator Crack the cylinder valve to clean out any dirt or dust
    · Mount the regulator onto the cylinder
    o Ensure that the oxygen pressure regulator is on the oxygen tank
    · Do Not over tighten regulator nut
    · Before opening the cylinder valve ensure that the pressure regulator screws are released (turned out)
    · Never use oil or grease on the regulators
    o Frictional heat as a result of high pressures can cause oil to ignite and possibly cause an explosion
    OXY ACETYLENE START UP PROCEDURE:
    These steps must be followed to ensure safe usage of this equipment.
    • Make sure pressure regulator screws are released (turned out) on both tanks.
    • Standing to the side of the regulator, Slowly open the oxygen cylinder valve fully
    • Standing to the side of the regulator, Slowly open the Acetylene cylinder valve ¼ turn
    • With the welding or cutting adjustment valves open, quickly adjust the working pressure to the desired amount
    OXY ACETYLENE SHUT DOWN PROCEDURE:
    After the equipment has been used these steps must be followed to ensure safe storage:
    • Close both cylinder valves
    • Open the welding or cutting attachment valves to release regulator pressure
    • Release pressure regulator adjustment screws
    • Wrap up hoses
    SAFETY EQUIPMENT:
    The correct safety equipment must be used when using the oxy acetylene equipment.
    • Wear shaded safety glasses
    • Use gloves during torch operation and when handling hot metals
    • Follow all safety rules for this and all other equipment
    OXY-ACETYLENE SAFETY
    Ø You must be trained and authorized before using the oxy-acetylene torch
    Ø Make sure you do not have a lighter in your pocket – they can explode!
    Ø Ensure gas bottles are upright and secure at all times
    Ø Do not allow oil or grease to come in contact with hoses or equipment
    Ø Perform all welding and cutting in the welding area – ventilation must be turned on
    Ø Approved goggles and spark resistant clothing must be worn when using the oxy-acetylene torch
    Ø Do not weld or cut a closed container
    Ø Make sure the work area is clear
    Ø Open the cylinder valves slowly – stand to the side!
    Ø Light the torch with the striker – do not use a match or a lighter
    Ø When welding, bend the end of the rod to identify the hot end and to prevent eye injury
    Ø When finished turn off the torch valves, turn off cylinder valves, then go back to the torch and bleed both lines
    Ø Keep the cylinder caps on when not in use
    How to Set Up, Light, Adjust and Shut Off an Oxy–Acetylene Torch:
    OVERVIEW:
    Using an oxy-acetylene torch is a simple and safe procedure if the correct process is followed. The process consists of three main parts:
    1. Setting up the torch
    2. Lighting and adjusting the torch
    3. Shutting off the torch
    WARNING: DO NOT OPERATE AN OXY-ACETYLENE TORCH
    WITHOUT PROPER EYE PROTECTION AND
    NON-FLAMMABLE COVERALLS. REMOVE
    BUTANE LIGHTERS FROM POCKETS.
    PROCEDURE:
    Setting up the torch:
    1. Make sure the regulator adjusting screws on both the oxygen and acetylene regulators are backed out fully counter – clockwise
    2. Open the acetylene cylinder valve ¼ to ½ turn
    3. Open the torch acetylene valve about ½ turn
    The acetylene valve lines up with the red hose
    4. Turn the acetylene regulator adjusting screw clockwise until 5 pounds pressure is read on the low pressure gauge
    5. Close the torch acetylene valve
    6. Open the oxygen cylinder valve all the way until the valve stops
    Stand out of the way of the gauges when opening the oxygen bottle to prevent serious injury if the regulator valve fails
    7. Open the torch oxygen valve about ½ turn
    The oxygen valve lines up with the green hose
    8. Turn the oxygen regulator adjusting screw clockwise until 5 pounds pressure is read on the low pressure gauge
    9. Close the torch oxygen valve
    10. Before lighting and using the torch, check the system for leaks
    11. Close the cylinder valves. If a cylinder gauge shows a pressure drop, there is a leak.
    12. If a leak is indicated, listen, smell and touch around all fittings and hoses, or use soapy water to find the leak.
    LIGHTING & ADJUSTING:
    Proper eye protection must be worn (shaded torch welding / cutting glasses)
    Proper non – flammable coveralls must be worn
    Remove butane lighters from pockets
    1. Put on proper eye protection and protective clothing
    2. Open the torch fuel valve no more than ½ turn
    3. Position the tip of the torch down and away from your body and hold the striker in your other hand so only the head of the striker is in front of the torch tip
    · Practice using the striker with the fuel shut off
    4. Use the striker to light the torch
    · Never use a lighter, matches, or other burning material to light the torch
    5. Adjust the torch fuel valve until the flame gives off little black smoke
    6. Slowly open the torch oxygen valve to create a neutral flame
    Neutral flame: (equal amounts of oxy/acetylene) has a rounded white inner cone used for fusion welding steel.
    Carburizing flame: (less oxygen) has a longer feathered blue inner cone
    a slightly carbonizing flame is used for brazing.
    Oxidizing flame: (excessive oxygen) has a short pointed white inner cone
    used for special purposes such as brazing with bronze filler rod.
    SHUTTING DOWN:
    1. Shut off the torch fuel valve first, which immediately extinguishes the flame
    2. Shut off the torch oxygen valve
    3. Close the acetylene cylinder valve
    4. Close the oxygen cylinder valve
    5. Bleed the acetylene line by opening the torch acetylene valve until the pressure reads zero on both the high and low pressure gauges
    (If the torch will be left for more than a few minutes and then reused, both lines must be bled before lighting the torch again)
    6. Turn the acetylene pressure regulating screw counter – clockwise all the way out
    7. Close the torch acetylene valve
    8. Bleed the oxygen line by opening the torch oxygen valve until the pressure reads zero on both the high and low pressure gauges
    9. Turn the oxygen pressure regulating screw counter – clockwise all the way out
    10. Close the torch oxygen valve
    These procedures and safety practices must be must be followed exactly because the equipment is potentially dangerous.
  2. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Great post :bow:
  3. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    this is important people, high psi 02 can explode when in contact with oil, so NEVER try to grease or oil the threads or any part of your torch!
  4. broc944
    broc944 1/2 ton status
    Sep 23, 2005
    1,660
    Northern Minnesota
    Exactly. I once saw the remains of a work van to which this happened. Supposedly the individual took his regulator off at sat it down in some oil that had spilled on the floor of the van, then went inside of the wholesalers and exchanged tanks, come back out and put the regulator on, he was killed instantly. The back of the van was really tore up. Every time I change tanks that image goes through my head.
  5. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    i had called a friend who got a used tourch set for and auction, and had oiled ALL the threads in the torch and was going to use it in about 5 min, i when to his house and de greased it for him, that was a close one.
  6. sponsoredbydad
    sponsoredbydad Dune Slaying Sand Junkie Premium Member GMOTM Winner
    Mar 12, 2004
    2,331
    402
    Dana Point "So Cal" "The sue me state"
    NICE!!!!!!! Hea rusty parts dood that is an excelent run down on how to use a torch. I hope it was not birthed by a tragady. would you mind if I printed that out to use as a guide for a safety meeting at my work. We have several newbies that could use this.
    chris:bow:
  7. ssped
    ssped 1/2 ton status GMOTM Winner
    Jan 5, 2006
    1,529
    Mission Viejo
    Thanks for the refresher. I took welding shop in highschool but that was many moons ago. Great info.
  8. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    hmmmm.....my oxy tanks are yellow
  9. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Excellent Post
    I recently purchased a torch set up and knew most of this information, but I did not know about the oil hazard!
    Thank you very much. :waytogo:
  10. throttleissues
    throttleissues 1/2 ton status GMOTM Winner
    Jul 15, 2007
    4,700
    Kern County
    An idiot I know had a job filling tanks. He was eating a Slim Jim at work and got oil on his gloves, while filling O2 tanks.:doah: One glove flared into a pretty good fireball, causing an investigation, and he got fired for being a dumbass. Luckily, he sustained no serious burns.
  11. trukker
    trukker 1/2 ton status
    Aug 3, 2003
    257
    Sebastopol Mississippi
    Yeah the o2 and oil/grease is mucho important. But also take heed of proper safety equipment. Glasses and gloves are the easy ones , but a lot of people over look thier choice of clothing. No frays, no shorts, proper shoes ,and use a long sleeve.A ball of hot metal will leave nasty burns. Trust me i've learned the hard way
  12. hillbillywizard
    hillbillywizard Registered Member
    May 16, 2011
    22
    South Toms River, NJ
    Also recommend taking cell phone out of pocket. Mine has a customized screen now.:doah: Glad it wasn't a lighter :eek1:
