Potty humor- "The Dump List"
Discussion in 'The Lounge' started by muddin4fun, Mar 22, 2002.
  1. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Potty humor- \"The Dump List\"
    The Perfect Dump -- Every once in a while, each of us experiences a perfect dump, it's rare, but a thing of beauty in all respects. You sit down expecting the worst, but what you get is a smooth sliding, fartless masterpiece that breaks the water with the splashless grace of an expert diver. But that's not the end of it. You use some toilet tissue only to find that it was totally unnecessary. It makes you feel that all is right with the world and you are in perfect harmony with it.
    The Beer Dump -- Talk about nasty dumps. Depending on the dumper's tolerance, the beer dump is the end result of too many beers. it could have been 2 or 22, it doesn't matter. What you get is a sinister, lengthy, noisy dump accompanied by a malevolent fog that could close a bathroom for days.
    The Chili Dump - Hot when it goes in, and rocket fuel when it leaves. The chili dump stays with you all day, making your tush feel like a heat shield.
    The Cable Dump -- Long, curly and perfectly formed like 2 feet of E13 telephone CO-axial cable. It loops lazily around the bowl, like a friendly serpent. You wonder admiringly, ''DID I DO THAT? Where did it come from?'' you leave the bathroom pleased with yourself.
    The Latrine Dump -- In case you didn't know, a latrine is a hole in the ground with a tent around it where soldiers, boy scouts and flies go to dump. Tip: Don't ever, ever look in the hole.
    The Mona Lisa Dump -- This is the masterpiece of dumps. It's as perfectly formed as it can be. Delicate and slender with intricacies that would make da Vinci weep. And just think, you made it yourself. You may even want to break out the Polaroid, but maybe that's going a bit too far.
    The Empty Roll Dump - You're done...you reach for the toilet paper only to discover that empty cardboard cylinder. A mild panic begins coldly in your throat. You could use the curtains...no, someone would say ''Where are the curtains?'' Then what would you say? The rug?...too cumbersome. Then you must come to the same conclusion that every ''empty roll dumper'' must face...Pull up your slacks, tighten your tush and wriggle yourself to the nearest full roll.
    The Splash-Back Dump - You send the dump on its way, it drops like a depth charge into the bowl creating a column of cold bowl water that washes your bottom with a startlingly unpleasant shock. Now you're wet and embarrassed. Tip: Blot instead of wiping.
    The Aborted Dump - You are in mid-dump when the phone rings. What do you do? ABORT! Pinch it off, go for the phone, and save the rest for later. It isn't pretty, but you've gotta do what you gotta do.
    The Alfresco Dump -- Everyone has had to go outdoors from time to time. This can be a rather pleasant experience really. The open air, the nature, and a good bush all contribute to the peaceful ambiance that our primitive forefathers must have enjoyed. What can screw up this harmonious interlude is a troop of Brownies or a patch of poison ivy.
    The Childbirth Dump -- This is a dump that is simply too big to go through the aperture provided by nature for the purpose. You sit there, thinking over your dilemma. First it hurts, and it isn't going to get any better. You wonder if you'll ever see your loved ones again. You imagine the newspaper headlines screaming ''Man dies trying to hatch monster loaf.'' You realize you'll have to resolve the crisis before you can leave the bathroom. Basically there are only three things you can do: Scream, call an Obstetrician, or just hope like hell have enough Vaseline to get you through it.
    The Tijuana Trot Dump -- The phrase ''[censored] Happens'' really applies here in a big way. When the ice in your tainted margarita makes contact with your lower intestinal tract, the fun begins. For the next 72 hours you'd be better off if you carried your own portable toilet with you because you will spend most of that time on the pot and the rest of the time in a fetal position. Now you realize why Mexico never had a navy.
    The Machine Gun Dump -- You're just sitting there in a state of sublime peace when all of a sudden you emit a group of noisy gassy bursts that break the silence like machine gun fire. The guy in the next stall hits the floor like a combat veteran, cradling his umbrella like an M16 and shrieking something about “damn Commies.”
    The Sound Effect Dump -- You feel a noisy one coming on. Relatives, friends or work mates are within earshot, so you must employ some clever techniques to cover the disgusting sounds you are about to emit. Timing is obviously very important here. At the precise moment of release, try the following sound effects: flush the toilet, sing the first two stanzas of your national anthem, or drop a handful of quarters on the floor
    The Security Dump -- You have enough on your mind when you're in the bathroom without worrying about a lockless door and someone bursting in to find you in mid-dump mode. So how can you prevent this embarrassing spectacle from taking place? One way is to strategically place your foot against the door. If you can't reach to do this... hum loudly.
    The Cling-On Dump -- For the most part you've completed your dump, but there's one little morsel that refuses to drop off. You're getting impatient. Someone else wants to use your stall. So, you grip the seat with both hands and wriggle, twist and pump but that last little stubborn piece just hangs there, suspended, clinging like a canned peach between you and the bowl water. Maybe the person pounding impatiently on the door has scissors.
    The Houdini Dump -- You go, then you stand up to flush, and the darn thing has disappeared. Where'd it go? Did it creep down the pipe? Did you dream the whole thing? Is it lurking out of sight? Should you wipe...maybe you should just to make sure you went. Should you flush? You'd better, because if you don't, you know it will reappear and smile at the next person who comes in.
    The Flu Dump -- You feel so bad that you don't know which end of you to put down first. You have roaring cramps, so you sit down. Then a wave of nausea rolls over you like a cold fog, so you stand up and cramps squeeze your intestines like a vice so you sit down again...up down up down. Don't you wish Mom were close by?
    The Porta-Pottie Dump -- Construction workers and outdoor concert goers will tell you about going in a portable toilet. My best description would be, “It's like taking a [censored] in an upright coffin.” It's claustrophobic and it smells bad... best advice... go in a paper cup.
    The Proctologist Dump -- In the beginning, the Lord created the earth, the sky and the firmament, but I hope he didn't create this dump, because there is nothing biblical about it -- you run out of gas. That's right, you run out of propulsion. The dump is right there at the end of your barrel and refuses to go any further. You grunt, you squeeze, you wriggle but it just stays there like a lump of lead. You've only got two choices here. One is to squeeze the damn thing back up your intestine and wait until next time. The other is to pretend you're a proctologist and go after it yourself. Not a pretty picture is it??
    The Whole Roll Dump -- No matter how much you wipe, it doesn't seem to be enough. You blow the whole roll and you have to flush 25 times too. The whole episode is consumer waste.
    The Graffiti Dump -- You flush the dump and the swirling motion of the receding bowl water forces the dump to the porcelain sides, scraping a creative squiggle on its way down. You flush again but the curlicue hangs there...love it or leave it. Its your choice.
    The Encore Dump - Ahhhh, you're done, so you wipe, put yourself together, wash your hands and are about to vacate the bathroom when you feel another dump coming. You have to return for a curtain call. The world's record is seven encores.
    The Born Again Dump - This is a dump that's going so badly, you say “Lord, if I live through this, I'll take up religion.” You always get through it, but seldom keep the promise you made in desperation, because a born again dump is like childbirth... you forget the pain quickly.
  2. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    Re: Potty humor- \"The Dump List\"
    The aborted dump LOL... Thats called holding hostages and after you answer the phone then you can release the hostages.../forums/images/icons/wink.gif
  3. MT ZION
    MT ZION Registered Member
    Dec 19, 2001
    58
    Ca, US
    Muddin4fun,
    are you on the computer all day or what?
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    Yes...this is by far the worst!
  5. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Okay, WTF is your problem???????? And reply this time!
  6. chevyfumes
    Feb 24, 2000
    38,584
    266
    Sickem Lara...GRRRRRRR/forums/images/icons/wink.gif
  7. chvyhs
    chvyhs 1/2 ton status
    Feb 12, 2001
    1,469
    Murrieta, California
    I hope you copy and pasted all that. Pretty good, I'll have to shorten it before I read it to my wife. She'll loose interest too soon.
  8. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    You are a seriously twisted person.......keep up the good work......
  9. MRBIGBLOCK
    MRBIGBLOCK 1/2 ton status
    Jun 25, 2001
    472
    paragould arkansas
    something stinks around here!!!!!!!!
  10. thatK30guy
    Jan 12, 2001
    32,076
    55
    /forums/images/icons/laugh.gif ROTFLMFAO!!! /forums/images/icons/laugh.gif
    Oh man! That was frickin' hilarious!! Tears streaming down from my eyes!! /forums/images/icons/laugh.gif
    BTW, I'm still trying to figure out what this one is: The dump where you splatter the whole inside of the bowl and when you stand up to view it, the WHOLE DAMN BOWL IS A BROWNISH-GREENISH COLOR!!! /forums/images/icons/tongue.gif This is when you have the diarhea! /forums/images/icons/wink.gif
    What the heck is that type?
  11. chevyfumes
    Feb 24, 2000
    38,584
    266
    It's the clogged nozle dump in order to fix this you must turn butt upside down and fart acouple times or clean hole with a needle.../forums/images/icons/shocked.gif
  12. thatK30guy
    Jan 12, 2001
    32,076
    55
    Gives a whole new meaning to the term...enema!! /forums/images/icons/wink.gif
  13. jekbrown
    May 19, 2001
    45,030
    363
    Vancouver, WA, USA
    rotflmao, a buddy at school has a booklet on the same subject... turdology. It has drawins to help describe each one (really ameture, but even funnier that way somehow). I oughta post some of them as a follow up someday. One of the ones it had was the "Werewolf poop: rarely seen outside Romania, this little devil can be identified by the bits of human bone and torn clothing within it. Should you ever come upon one of these, pack your things and move to your mothers immediately!" etc etc, funny as hell. Anyway, awesome post, I was in tears for several minutes. LOL!! /forums/images/icons/laugh.gif
    J
  14. chevyfumes
    Feb 24, 2000
    38,584
    266
    theres also the STONE POOP ussualy passed through the urethera followed by screaming...sorry had to../forums/images/icons/wink.gif
  15. Chaz88K5
    Chaz88K5 1/2 ton status
    2,979
    Stockton/Lodi CA
    speaking of takin a dump....i think i am goin to go drop the kids off at the pool. /forums/images/icons/laugh.gif
  16. thatK30guy
    Jan 12, 2001
    32,076
    55
    And I'm gonna go drop a bomb!! /forums/images/icons/wink.gif
