Pounds of refrigerant?
Discussion in '1936-Present Suburban' started by porboy, Aug 12, 2002.
  1. porboy
    porboy Registered Member
    May 7, 2002
    29
    Poway Ca.
    I am refilling my subs a.c. system(front and rear)with r134a and was wondering if any of you guys had a ruff estimate on how much 134a the system should hold. I already put about three and a half pounds in. The front is running ice cold but the rear is not. The refrigerant pressure only reads about 40 lbs. on my gauge. Any help would be appreciated.
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    5.25lbs
  3. porboy
    May 7, 2002
    29
    Poway Ca.
    Thank you very much /forums/images/icons/smile.gif
  4. BXwildshot
    BXwildshot Registered Member
    Sep 17, 2001
    97
    Bronx , NY
    The expansion valve in the rear unit might be bad.
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Fill 80-85% of the original r-12 when using r-134 as a replacement. 40 pounds on the low side sounds alright. Keep in mind that a warm engine compartment or ambient tempature will cause that number to rise. Winding it up will cause it to move too.
