Power Ateering
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JTB, Jul 23, 2001.
  1. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    I just installed a new pwr steering box and pump. A friend of mine said to run ATF instead of power steering fluid, but the guy at NAPA says to run power steering fluid. Which is correct? Thanks
    Jeff
  2. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I am running PS fluid but I have heard of ATF being used too.
    There is a new product out there I just read in 4-Wheel and it is suppose to keep the pwr steering system alot cooler...I can't remember the name off hand!
    As for your question I don't know wich is better so I just use PS fluid.
    <a target="_blank" href=http://www.geocities.com/baja/5099>www.geocities.com/baja/5099</a>
  3. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    JTB
    If you don't mind my asking, how much did your box and pump cost, and is it new or rebuilt, and for 4wd or 2wd (box). I just pulled my box off the Jimmy and am considering going through it "just because", but would consider a new one as well.
    JB
  4. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    The box was 175 and the pump was 55. I bought them from All Parts but I got a discount because a high school friend handles my purchases. I can't remember how much they were supposed to be. Both are rebuilt. I am running power steering fluid but I was not sure if ATF is recommended. Huge improvement in steering responsiveness after instaling the new box but it still whines pretty loud. Maybe it just takes a little while to get all the air out of the system.
    Jeff
  5. JTB
    JTB 1/2 ton status
    Dec 5, 2000
    192
    CA
    I forgot to mention that it is a 4wd box. (70 Chevy K5)
    Jeff
  6. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I have always used ATF. Power steering fluid is the same thing only in a different package and more $$$ (unless you have a Honda they have to use special stuff because Honda engineers are morons). When your truck was made there was no such thing as power steering fluid.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
