power brake booster vaccum hose ran off back of intake right behind the carb.
Discussion in 'The Garage' started by down4thakrown, Jul 30, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    my tranny vacuum and power brake booster are ran off a splitter coming from the intake right behind carb. is this okay? i plugged the vacuum coming outta the back of carb. how can i tell if i got a vacuum leak back there?
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Spray something on it while its running to see if idle changes . You don't neccesarily need to use something flammable .
    Why not run the brakes off the carb with the hose from your 83 ?
    You may need an adapter for the metal tube for some carbs , but some you don't . If I remember right the factory metal brake hose adapter threads right on to Edelbrocks , and use a small adapter for Q-jets .
    Run the tranny off the x-mas tree on the back of the intake , and cap the unused lines .
  3. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    because the intake i have puts the vacuum piece behind the carb to close to the carb so there no room. barely enough room for a plug. the piece i have hooked up to it has 2 other places to put hoses one has the tranny goin to it and the other i plugged. where i got the brake booster hose hooked up at the hose was too big so i took some spectre caps cut the tip off them and slipped to of them over it and made a snugg fit and used a hose clamp. thats why i ask how to check for vaccuum leaks. this shoud be okay right?
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    90 degree elbow with hose barb and rubber hose then , will look cleaner than a tee or something . Could do that to the tranny line as well and almost get it to lay flat on the intake :D
  5. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    thats what i got is a tee. but with 3 ports. with one plugged.
  6. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    but the way i have it will work right?
