power chips, do they work?
Discussion in '1992-Present Chevy & GMC models' started by deek, Nov 15, 2004.
  1. deek
    deek 1/2 ton status
    May 6, 2003
    142
    Great Bend, KS
    & if so what stage should i get 1 or 2, I'm thinking maybe a stage 2 because I'v had ths cats removed, now I'm running tru duals with headders & flomasters, & the intake side has a TBI spacer with a 8"x14" air cleaner.
    Also fuel mileage is a factor, does it stay the same under normal driving conditions?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    increased mileage? I doubt it. Increased gas cost? definetally. You have to run Premium with one of those chips. All they do is adjust the timing and fuel a little bit. A custom chip is a better option but for your setup i wouldn't waste the money. You'd make more power spending money on a bigger throttle body and fuel pump. http://www.turbocity.com/ sells TBs and look on Ebay for cheap high flow throttle bodies.
  3. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I am fairly sure that you won't need a new fuel pump, you might want some kind of adjustable fuel pressure regulator to kick up your fuel pressure. I don't really believe that a bigger throttle body will help that much either, unless you have done heads, cam, intake etc. Best bang for the buck I would say cam, and if you have the money heads and intake, but if you do any of those will you have to get a custom chip burned. Go to PCMforless.com to get a chip burned.
  4. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I don't see any reason for a custom chip with intake and head swap.
  5. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    i know they dont do anything for my camaro's, the custom (diy) ones are the way to go if you're gonna do it, but I think unless you have some major mods, it's not worth it.
  6. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Of all the things I have done to squeeze more power out of my 98 vortec k1500 is I installed a duel electric fan. flexalite. I alse have a volant air system, jba headers, duel flowmasters, hypertech tuning, mass air flow sensor, and a helix throttle body spacer. what's next ........ whipple supercharger! /forums/images/graemlins/rolleyes.gif
