Power for Electric Fans
Discussion in 'The Garage' started by Art'74, Mar 29, 2005.
  1. Art'74
    Art'74 1/2 ton status
    Dec 21, 2004
    145
    OKC
    Hey all! Please let me know where you have gotten power for dual electric fans that is switched by the ignition. I will also have a separate switch but I don't want the surprise of a dead battery because I left the fans on after turning off the truck. TIA.
    Art
  2. eds77k5
    eds77k5 1/2 ton status
    Oct 19, 2001
    383
    washington state
    there is a good write up in the tech section with wiring diagram, hope that helps ya out :cool1:
  3. dyeager535
    26,977
    Just run the fans off the temp switch with constant 12V power to the relays.
    Many automakers do this, (including GM) in your case with your fuse panel, that's probably the simplest way to do it. Even "better" if you use the fan switch mounted in the radiator, since that will cool faster than a block mounted switch.
