Power lock switches
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dave_90_blazer, Mar 20, 2004.
  1. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    anyone know where I can get new power lock switches for my 90 K5 Blazer?
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Autozone /forums/images/graemlins/thumb.gif
  3. dave_90_blazer
    Jan 1, 2004
    688
    will I have to go to the counter?
  4. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    unfortunately for you, i think so..
  5. barryb
    barryb Registered Member
    Oct 15, 2003
    51
    Springfield MO
    i vote install a keyless entry system ...
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have switches in this 86 out here, want them ?
  7. dave_90_blazer
    Jan 1, 2004
    688
    do you know if they are good?
    mine only work in 1 direction (unlock)
  8. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    check the wiring on back of the switch, I thought mine went bad but the wires broke off the connectors in the plug on the harness... you might need the harness ends instead. I replaced mine and the switches still work /forums/images/graemlins/waytogo.gif
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope. They're in the motormite (HELP!) section. On the sales floor.
    Any store that carries motormite/dorman will have them. Nearly every store will carry motormite/dorman as well.
  10. dave_90_blazer
    Jan 1, 2004
    688
    I checked in thew help section, all I found was window switches
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Window switch and door lock switch are the same thing.
  12. kw48653
    kw48653 Registered Member
    Sep 16, 2003
    86
    try taking them apart and cleaning them before you relace them. it worked great for me.
  13. dave_90_blazer
    Jan 1, 2004
    688
    nope, the window switch has 5 pins, the lock switch has 3
    I just ordered them, $20 each
  14. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    You guys might find this idea amusing and laughable...that is, until you try it.
    About a year ago, both power lock switches on my truck were terrible. I had to push them really hard in order for them to work either way. I figured they were shot anyway, so why not get creative. I got to thinking, WD-40 fixes a lot of things, right? So, I took my WD-40, put on that impossible-to-find red tube thingy, and shot some WD-40 right in my power lock switch. (Just gave it a squirt or 5 right over and under the tab you press on). BAMO! Work like they did on day one. I guess the contacts just corroded over time and the WD-40 dissolved the corrosion away. They still work great and I haven't had to WD 'em since. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
  15. dyeager535
    26,982
    191
    Never tried the WD40 trick, but I had some window and door lock switches that didn't work, so I took them apart, and sure enough, it's just copper contacts, and they were all corroded. Cleaned them up, put some grease on them to hopefully prolong the time before next tear down, and they worked like a charm.
    Only time a switch probably needs to be replaced is when one of the pins breaks off, only thing I've ever seen wrong with one that wasn't contacts.
  16. dave_90_blazer
    Jan 1, 2004
    688
    the chrome is all worn off mine, so why not
  17. heavy4x4
    Aug 28, 2002
    3,270
    Well?
    Did I just save you $40?
