power lock
Discussion in 'The Garage' started by TXFSHRMAN, Jun 29, 2005.
  1. TXFSHRMAN
    TXFSHRMAN Registered Member
    Jun 22, 2005
    22
    DEER PARK, TEXAS
    i have a problem also with my power lock on my passenger side it will not lock with the switch i was reading the other threads and couldnt find anything with that......i can lock it and open it outside with the key...can anyone help
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Does the drivers side switch work the lock?
    . IIRC the switch on the drivers side is the master switch. (i could be wrong).
    If the lock can be operated from the drivers side switch than the problem prolly is in the pasenger switch/wireing. If neither switch operates the lock the the problem is in the drivers side switch or the lock may have a bad solonoid.
