power loss from tbi?
Discussion in 'The Garage' started by shaun89, Jan 10, 2007.
  1. shaun89
    shaun89 1/2 ton status
    Aug 7, 2005
    1,942
    center of CT..ish
    i plan on getting a crate engine with 415hp and 445ft lbs and it comes with everything but the carb, i found an adaptor plate to put on a holley tbi set up and i emailed hi-tech engines about it, he said there would be "extreme power loss" if i used the TBI...has anyone experienced this or is he just wanted me to put on the recommened 850cfm carb they test them with?...sorry about the long post
  2. sweetk30
    Nov 1, 2004
    25,552
    547
    horseheads , ny 14845
    if you want tbi but still power look in to 4 barrel tbi unit or tuneport. stock just wont flow your needs even with mods for best results.
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    even a stock TPI will be a bit of a restriction compared to an 850 carb
  4. dyeager535
    26,982
    191
    A bit? Try about 300CFM lol. :)
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    What Holly TBI system are you looking at?
    If you use the right HolleyTBI system you should have no power loss at all and get way better driveabilty over the carb. Holly makes TBI systems that will easily support 415 HP or more. The 950 Comander TBI will support over 500 HP. You dont need any adapter plate. The TB will bolt to any square flange manifold.
    Maby the guy thought you were talking about stock GM TBI or the 670 CFM Holley which will not work with the engine you are getting.
  6. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Thunder is right, the stock TBI will in no way support that kind of horsepower. Even holleys 670 wont come close to supplying enough fuel for that motor. However a complete aftermarket system from holley or even eldebrock has a system I believe, will support that motor.
  7. shaun89
    Aug 7, 2005
    1,942
    center of CT..ish
    damn...thanks all the help guys, holley makes a 900 cfm tbi? would that connect right up to my stock plugs and all that fun stuff thats on there now?..again...u guys save me:bow:
  8. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,996
    134
    Nope, you'd pretty much have to buy the whole Holley setup.
