Power Modules for Chevy/GMC Doge Ford
Discussion in 'Vendor Forum' started by tdd, Nov 22, 2004.
  1. tdd
    tdd Newbie
    Nov 22, 2004
    4
    Here at Top Dog Diesel we have the most powerful power modules you can buy for the Chevy/GMC Doge & Ford diesel engines.
    Call us at 602-288-7207
    Regards,
    TOP DOG DIESEL
  2. CK5
    May 19, 1999
    21,625
    702
    CO
    Hi Clay
    Do you have any specs for your D-max chip?
  3. tdd
    tdd Newbie
    Nov 22, 2004
    4
    The Quadzilla Stealth Tuner for the GM Duramax is the ultimate programmable hand held programmer for performance and features. We are offering four models of this great new product, one for towing one for high performance one for racing and one for competition. The Towing Model is available with 50hp, 70hp, 90hp and 110hp levels. The Performance Model is available with 70hp, 90hp, 110hp, and 135hp levels!  In addition to hp gains these modules will offer incredible fuel mileage and cooler exhaust temperatures than any competitor due to our precise timing maps.  The Racing Model is available with 70hp, 110p, 135hp and 165hp levels.
    The Competition Model is available with 215hp and any three additional lower hp tunes.  EXAMPLE: 70hp, 110hp, 135hp, 215hp.
    The Stealth tuner also gives you the option of removing your top speed limiter, as well adjust your speedometer and odometer for the correct tires size. You also have the ability to pick and choose the options to best suit you. For those that have warranty concerns or just like to have the ability to have more information the Stealth tuner also gives you the ability to read and erase engine fault codes if needed! All this in less than 10 minutes without getting your hands dirty! If you decide to change power levels you can do so in less than a minute.
    For those of you that already have a performance module, but would like even more power the Stealth can be custom programmed for your truck. The Stealth Tuner also has the ability to modify your Speedometer and Speed limiter without changing the hp level.
    Towing: 4 power levels up to 110hp 215 ft lbs of torque
    Performance: 4 power levels up to 135hp 280 ft lbs of torque
    Racing:  70hp, 110hp, 135hp, 165hp
    Competition: 215hp and any three additional lower hp tunes
    Change Tire Size and Speed limiter with either model.
    Top Dog Diesel /forums/images/graemlins/truck.gif
    602-288-7207
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    we've got a 1998 dodge 24v cummins pickup here. do you make anything for this model? we'd like to get some more power for towing/around town driving.
  5. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    How big of a tire does it recalibrate to for a Duramax? And what ratios? Thanks.
  6. tdd
    tdd Newbie
    Nov 22, 2004
    4
    The Quadzilla Power Module is a fully programmable digital device that plugs into the Duramax engine and precisely alters fuel injection quantity and timing to give an improved power and torque output. The Quadzilla Power Module has been very carefully tuned to give optimum power and torque while retaining a smooth and progressive power curve. Throttle response is improved but remains predictable. The Quadzilla Power Module alters fuel injection timing and fuel injection quantity, both of which play a part in improving the power and torque output.* This product does not increase fuel pressure.
    Fuel delivery is increased to a give an ideal air/fuel ratio at full throttle for maximum power with clean exhaust, from idle to full revs. The extra fuel at full throttle is gently blended back so when the throttle is closed there is no extra fuel being added.*
    Combined with software interpolation across the table of data values this gives smooth and predictable throttle response at all times. Advancing the injection timing on a diesel engine helps keep the exhaust gas temperatures low which is a key factor in engine reliability and helps eliminate black exhaust smoke. EGTs with the Quadzilla power Module fitted are kept at sensible low levels.**
    Advance injection timing also improves power output without adding any fuel.* This places less strain on the fuel system for a given power increase and can help fuel economy.*
    We also offer higher levels of horse power on your request.
    The Quadzilla Power Module is a very highly specified unit. It has many features that make it the first choice for Duramax Performance.
    Add power to your truck today.
    TDD 720-207-9011
  7. white-rhyno
    white-rhyno 1/2 ton status
    Jan 27, 2002
    942
    Ellensburg Washington
    How bout a 2000 24v?
    Pricing? Power?
