power of a 350 with 38's ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by wheelin247, Jul 20, 2001.
  1. wheelin247
    wheelin247 1/2 ton status
    Aug 29, 2000
    178
    hayward,ca
    power of a 350 with 38\'s ?
    howdy ya doin i plan on gettin a brand new stock 350 and puttin my old edelbroke intake and carb and headers on and i have flowmaster exaust i have 1 ton axles im puttin and and i plan to put 4:88's or 4:56's in there and i was wonder if my th350 tranny if on the freeway those gears would be to high and wined the motor out to much ......and also do u think that it would have enought power to turn 38's with no problem ?>
  2. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    Re: power of a 350 with 38\'s ?
    right around 25-2600rpm @ 55-60 mph
  3. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Heres a link to SuperLift's gearing chart. <a target="_blank" href=http://www.superlift.com/gear.htm>http://www.superlift.com/gear.htm</a>the link has a chart and all the ness. math forulas you will need. The chart is based on a speed of 65 miles per hour. I am running 38s and 488 gears also, w/ a TH350.
    Out of 100,000 sperm, YOU were the fastest?? [​IMG]
  4. michaelm
    Feb 2, 2001
    872
    you should throw a tape measure on your '38s' from centre of wheel to ground to see the actual radius you are working with. my truck @ near 6000# with 8:1 350 4.88s and sm465 is no highway hauler but it is drivable
  5. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    But on the flip side at speed tires will grow in diameter. Ever watch a top fuel car??? Granted those tires are a much softer casing, but tires do grow at speed due to centrifugal force.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Tire growth of dragsters is caused by centrifugal force? I thought heat was the cause.
    Tim
  7. wheelin247
    Aug 29, 2000
    178
    hayward,ca
    so i would be able to go like 65 on the freeway at like 5000 rpms?..i wouldnt but that would be around that ballpark right
  8. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    I would think heat AND centripital force would equal expansion of a drag tire.
  9. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    UUUMMMM......... NO. w/ 4:88's you'll be turning around 2800 at 65. That is a very comfortable cruising RPM.
    The tire growth comes from the centrifugal force, Think of when they do a burn out, the tire snaps up to a much taller and narrower profile. The instant they let off the loud pedal it goes back into the normal shape. And as a side note at the top end of the track a drag slick will be flat on the back side of the tire (to the back of the car that is) It looks really weird!!!
  10. wheelin247
    Aug 29, 2000
    178
    hayward,ca
    does 4:88's give u good power with that 38's off road or should i go a little more like 5:13's ?becuase i do travel and stuff to go to the trails so i need decent for drivin to.
  11. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    IMO I think the 4:88's will be optimal. They will give good power and good drivability. Did you check the link I put in my 1st reply?? Those are figured at 65 MPH. If its a trail rig go as low as you dare but yours is a driver so figure out what the max speed is youll be traveling and figure it up from that. I personally would not want to be above 3500 for extended periods. The link I gave has all the math formulas youll need to figuer out whats best for your needs.
  12. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yeah, you're right. I was just at the drag strip Tuesday so I watched exactly what you were talking about.
    Tim
  13. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Did you see the tires at the big end? They look soo weird!!!
  14. lukerz
    lukerz 1/2 ton status
    Apr 13, 2001
    109
    Western Mass
    Is there a optimal rpm for 65 mph?
    Lukers
    83 K10 from 76 K5 & 83 C10
    Th350 Np203 355 CID
    31 X 10.5
    Plan on 2" body lift
  15. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    IMO around 2800- 3200 is best for @ 65 MPH. Any higher and you will prob go nutz listening to the rig at speed! A friend of mine had 4:11's in his camaro, even w/ o/d the car was wrapped up pretty tight for a long haul. It wasnt hurting the car but if you listen to 4000 plus RPM for long enuff thru flowmasters your ears will ring when you get to your destination. You'll still hear the car screaming for hrs!!! which may not be a bad thing really!![​IMG]
  16. lukerz
    Apr 13, 2001
    109
    Western Mass
    What if you are running lower rpm's ?Let's say 2100??
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
  17. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    2100 @ 65!!!! What do you do idle thru town at 30!?! WAY TOO LOW! If you have 38's and your runnin 2100 @ 65 you have 3:73 gears and need to go to a 4:88. IMO Thats if you dont have an O/D. if you have an O/D maybe a 5:13.
  18. lukerz
    Apr 13, 2001
    109
    Western Mass
    I have tiny tires 31's the chart puts me at 2100 at 65mph. Sometime in the future I will get lower gears(waiting for the right deal)
    Lukers
    Th350 Np203 355 CID
    31 X 10.5
  19. Pure Insanity
    Mar 17, 2001
    4,579
    Dade City, Florida
    Oh yea, your sig has your tire size. DOH!! I guess you have 307s. You definately need more gear before you get more tire. Yea you can drive w/ 38s and 307s but it wont pull a worm out of a chickens ass. Definately invest in gears before getting any bigger IMO. Whatever size you go with. (I just used 38 as an example)
  20. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    i had 307's with 33's and he is right the thing would not get out of its own way. and it would not even stay in od going up an over pass on the exspressway. however, i think it would top out at about 743 mph lol.
    411's and 33's and it will outrun the wife volvo of the line. you might be a redneck if your wife has a new volvo wagon and you convince her to drag race????????
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
