Power passenger side mirror replacement question...
Discussion in '1992-Present Chevy & GMC models' started by heavy4x4, Mar 14, 2003.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Anybody done it?
    My dad's '97 suburban is in need of a new one because the case is busted. I can buy a new one off of e-bay for around $55. Sound like a good deal? Remember, these are the power mirrors. And, more importantly...what's the replacement procedure like? Is it strictly a bolt on piece and plug in the wiring, or do I have to take apart the whole freaking door? Thanks for your help.
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    Don't quote me on this, but it should be a pretty well painless operation. I haven't had a Burb door apart, but most of the newer vehicles are pretty easy. Remove door panel, remove nuts or screws from mirror holding it to the door, unplug power supply to mirror and install the new one in reverse. The door should have access holes for the mirror mounting screws, the only problem you might have is reaching the plug for the mirror. Some of the plugs are P.I.T.A. to reach but it can be done. Hoped that helped.
    Krennen
  3. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Did mine on my 96 Tahoe. The plug was on the outside. I just had to unbolt and unplug. /forums/images/graemlins/thumb.gif
  4. bigred350
    bigred350 Registered Member
    Jan 29, 2003
    11
    florence AL
    you should not have to take the door panel of if you are just replacing the mirror. all that is need to come off is the little triangled piece of plastic in the corner of the door. then just take the bolts off and undo the wiring harness and plug the new one in and bolt it back on.
  5. heavy4x4
    Aug 28, 2002
    3,270
    Thanks all - will give it a shot some time soon. /forums/images/graemlins/thumb.gif
