Power Rear window key!???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 82Jimmy, Jul 9, 2000.
  1. 82Jimmy
    82Jimmy 1/2 ton status
    Jun 9, 2000
    702
    Does it use the same key as the door? I can't get mine to work...I have seen it work, but I don't know what key it uses. Thanks
    <font color=blue>If its too loud, your too old.</font color=blue>
    <font color=red>Cameron</font color=red> <font color=green>Burnett</font color=green>
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
  3. 82Jimmy
    Jun 9, 2000
    702
    It will go in, but won't turn....
  4. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
  5. 82Jimmy
    Jun 9, 2000
    702
    I will, if you don't think it will mess up the motor or something...do you really think that will do it? My dad used it a couple of times, but he was thinking it was the broken off key that I have...
  6. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    Those things sieze up big time. They should use the same key as the doorlocks. Mine is fried too...you can take it apart and maby have a locksmith try and fix it, it would be cheaper and you would still be able to use the same key
  7. 82Jimmy
    Jun 9, 2000
    702
    Thanks for the clear up guys...i will jump right on it! after the critical condition of the brakes though...
  8. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    Last time I washed the Ole Gal, I got too much water in the lock and it seized up. I did just as was explained here , I sprayed it down with wd-40 and it is back to working.
    Way..way..way back in the posts a similar problem came up and I explained in detail how to repair the lock and switch, for those short on cash and long on curiosity...
    <font color=green>[​IMG]Eagle86K5[​IMG]<font color=red>
    Masonry...It's a Good Thing
    2B1ASK1
