power rear window
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87project, Aug 27, 2002.
  1. 87project
    87project Registered Member
    Jul 9, 2002
    98
    Alabama
    how do i get to the inside of the outer tailgate latch to hook the wires back up that previous owner disconnected?do i have to take the whole window out? /forums/images/icons/confused.gif
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    to gain access to the 2 mounting nuts that hold the handle on you have to take off the inner access panel, bypass the window safety switch to roll up the window with the tailgate down. Should be able to get to them then.
  3. 87project
    Jul 9, 2002
    98
    Alabama
    appreciate the help! /forums/images/icons/smile.gif
  4. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    the window won't roll up when the tailgate is down, usually if you click the left tailgate latch closed with the tailgate down it will let the window roll up. be sure to support the glass as it rolls up.
  5. dogman
    dogman 1/2 ton status
    Oct 31, 2001
    213
    California, Santa Clara Co.
    don't give up, in my 85'K5, the brushes can be replaced in the rear window motor. I went to an autoparts store looked at all the alternator brushes. I found what looked close. then used a benchgrinder, to correctly get the brush the right size. solder them in place. they still worked when it was sold 5 years later.
    was a long time ago but thought the inside tailgate had screwed on covers to gained access.
    I paid 85 cents, chevy dealer wanted 75$ for an assembly!/forums/images/icons/mad.gif
    <font color="orange">dogman </font color>
