power steerin
Discussion in 'The Garage' started by wannabeblazer, Jul 3, 2005.
  1. wannabeblazer
    wannabeblazer Newbie
    Feb 24, 2005
    Boerne, TX
    i have an 83 k5 blazer and every time i turn the steering wheel all the way to either side it squeks. any help would be nice
  2. Grieby54
    Grieby54 1/2 ton status
    Jun 18, 2005
    782
    Houston, TX
    Add more fluid... if that doesn't work... get someone to get in and turn the wheel and look for the squeeky spot and hit it with some DW40
  3. wannabeblazer
    Feb 24, 2005
    Boerne, TX
    its got all the fluid it needs and belts are tight
  4. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    The problem is AGE. My rig does the same when it is fully turned. Thank your lucky stars it's not a Ford, they wine like an old dying dog.
  5. Grieby54
    Jun 18, 2005
    782
    Houston, TX
    I'm not talking about the belts... I'm talking about the knuckles along the way to the gear box from the steering column..
  6. LongIslander26
    LongIslander26 1/2 ton status
    Jun 25, 2005
    256
    Park County, Montana
    power steering
    Maybe it's because the steering linkage has reached the limits of it's travel and the pump is applying pressure against that, but it's not moving anything.
    Just a thought... :thinking:
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    dont hold your steering all way to the stop
    even in my 81 c-10 you cant hit the stop or will will LOUDLY chirp!
    you cannot go all the way with the steering
    it sounds like this is what you are having happen to me
    it is the steering box bottom ing out, hitting internal stop, will not turn wheels any farther no matter how much you modify the stops on the axle/control arms/spindles
    good luck
  8. LongIslander26
    Jun 25, 2005
    256
    Box bottoming out
    You MAY be able to adjust that out with the toe adjustment (Tie rod ends), and then recenter the wheel with the steering arm drag link adjuster. MAYBE. OR, if it only does it one side, SOMETIMES you can loosen the steering shaft off of the gear box, turn the box back in one turn, reattach the steering, and then straighten your wheel from there. It depends on how much travel is left in the linkage when the box hits it's limit.
  9. Storm Trooper
    Nov 24, 2000
    4,640
    If it squeals all the time, replace the pump.
    If it only squeals when it heats up, get a tranny cooler and mount it in front of you radiator to keep it cool.
    connect it to the return line.
    If you put in a new one, the cooler is still a good idea.
