Power Steerin
Discussion in 'The Garage' started by ndestroya, Aug 31, 2005.
  1. ndestroya
    ndestroya Registered Member
    Jun 13, 2005
    26
    New Jersey
    I recently had a 350 built fior my 83K5 and i need a power steering pump bracket for my motor, i was wondering if anybody knows where i can order one for my truck instaed of gettin one from a junkyard cause they are trying to make me buy the whole pump which i do not need.
    Thanks, Josh :confused:
  2. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    Only one place..
    The Dealer is the only other option other than a boneyard..Unless a place like LMC has them...Call a dealership's parts dept.--I bet they have or can get one,and usually they are not too expensive..I bought one for a 454 from the dealer because no one had a used one available..it only cost 11 bucks !..I thought they'ed want 50 with my luck!.. same deal when I needed a plow pump bracket for a small block--wasted half a day making one,and I later learned the dealer sells them for about 15 bucks! :blush: :surepal: :screwy: :crazy:
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Post up in the wanted section . Many of us have brackets lying around .
    What was wrong with the original bracketry ?
    All of your external accessories and brackets will bolt on to the new engine if you replace a 305 ( assume you had ) with a 350 . They are same externally .
    If you had a diesel , then you need brackets .
  4. ndestroya
    Jun 13, 2005
    26
    New Jersey
    power steering
    yeah i will call the dealer today and see what they can do for me, my original brakets do not fit for some reason because of the headers i have on my truck for some reason. Thanks so much for you input i'll let ya know how i make out
    Thanks, Josh
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Replacement brackets won't work either then .
    You need to get a bracket from the aftermarket to work with headers . Its only for the back bracket , you can keep the front bracket on the pump .
    Try Jegs or Summitt
  6. ndestroya
    Jun 13, 2005
    26
    New Jersey
    power steering
    thanks alot man i am gonna get on the phone with summit and jegs after i hook up my fuel pump today. I appreciate the help alot being as i'm a 17 year old kid building my first truck pretty much by myself.
    Thanks, Josh
