Power Steering Box pressure line fittings
Discussion in 'The Garage' started by k20, Mar 6, 2004.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Quick question, the high pressure line that goes from the box to the back of the power steering pump, the fittings on the pump end are the same between a 2wd and a 4wd are the steering box end fittings the same? The 4wd box is an 87 and the 2wd is an 88 burban so its the same body style. Thanks.
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Yep, they should be identical. Only difference is the sector shaft.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    but in 1980 the seats and end of lines changed design over to an O ring type and so are not normal flared seat design anymore
    watch out on that
  4. Esteban86K5
    3,712
    Bakersfield, CA
    But both etrucks are older than 80 so it's shouldn't be a problem. /forums/images/graemlins/waytogo.gif
  5. dyeager535
    26,979
    And the fitting can be removed as well, so it wouldn't matter if they weren't.
    The valves (under that fitting) are different depending on application.
