power steering box question
Discussion in 'The Garage' started by makovai, Jan 28, 2007.
  1. makovai
    makovai 1/2 ton status
    Jun 6, 2006
    854
    oregon city
    I searched all over this forum and bascially get an answer of "dont adjust the sector shaft"
    Heres the deal. I got my cross steer all done, with the xj shaft. The truck is all over the road. So i start checking things and what i found is the i can grab the xj steer shaft and spin it about 20 degrees with the truck off and sitting in park. This is exactly how it drives too. like im turning the wheel alot before they actually move.
    Did i get a worn out steering box from the wrecking yard?
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Most likely; you should have went with a re-man 2wd box.
  3. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    With the wheels pointed straight ahead loosen the lock nut on the sector shaft adjusting bolt. You will need to turn the adjusting bolt clockwise to remove the slop from the steering box. Make sure you don't go too far or the steering box won't go beyond center.
  4. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    Adjust it a little bit at a time, till gets to where you want it
