Power steering bracket
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1975k5, Jul 17, 2002.
  1. 1975k5
    1975k5 Registered Member
    Feb 28, 2001
    44
    Alabama
    For those of you who have installed headers on your 350, which bracket did you use for your saginaw power steering pump?
    Tom
  2. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    I used the stock one but made a spacer to take up the difference between the thickness of the stock manifold and the header flange.
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    i had to make one from scratch, it the bracket the the pump uses to hold the tension for the pump. the one i made bolts to the side of the head and come down at an angle from there and i just tac welded a nut to the back side of it /forums/images/icons/grin.gif
