Power steering comes and goes.
Discussion in 'The Garage' started by hunterguy86, Jan 9, 2007.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    My power steering comes and goes on my 86 K5. This started the other day when I was cutting some donuts. I remember cutting donuts and then hearing the pump squeel some. I let off the gas and straightened out the wheels. At that point I had no power steering.
    I parked my k5 and went to bed cause it was late. The next morning I checked my fluid, which was full. I started the truck and I had steering again. I've been drivin it since. The powersteering seems to come and go. I lose it ususally when I have been driving the truck and everything warms up.
    So what did I do? Did I burn up the pump? Should i take a hose off and drain the fluid and put more in and then bleed the air? Any other advice?
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    make sure your belt is tight, and not glazed
  3. hunterguy86
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Ya I checked the belt. It is tight and the pump does not make any squeeling noises, like it would if the belt were lose.
  4. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    I had to replace a pump on an 85 because, at idle, the pump did nothing. Rev the hell out of it and it worked.
  5. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    probably not the pump...
    A power steering pump either works,or it does not,usually--no "intermittent" power assist or lack thereof ..if it were the pump you'd hear it whining like it was low on fluid,or the belt squealing..
    I'd guess you have a partial blockage in one of the power steering hoses, or the box itself perhaps,or the pressure relief valve in the pump is sticking or has a broken spring,allowing pressure to by-pass the steering box and dump back into the pump..foamy fluid with lots of air can cause this also,overfilling is a common cause of that..a bad power steering box can cause "lumpy" steering ,even with a good pump too...:crazy:
  6. jamber2541
    jamber2541 1/2 ton status
    Apr 10, 2006
    424
    e.p. texas
    x2, when I rebuilt my engine I took the time to clean everything else including the power steering pump and you would not believe how dirty those things can get.
