Power Steering Cooler how to?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MaxCrack, Aug 10, 2001.
  1. MaxCrack
    MaxCrack 1/2 ton status
    Apr 10, 2001
    895
    Mt View, CA
    I have the AGR pump and steering box. I have read in a few posts about these that they tend to get pretty hot. So I was thinking about putting in a power steering cooler. But I havn't had much luck finding information about this. Does anyone actually make a power steering cooler, or do I need to use something else, like a transmission cooler? Also, where should I put it, and which line should I connect it to?
    Good things come in small packages. Good things come to those who wait. So, if you're waiting for a small package, that must *really* be sweet.
  2. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    Don't put a power steering cooler on it....they're wayyyy tooo small. I would put a tranny cooler on it in stead. I currently have a powersteering cooler on mine and I will be switching out to a tranny cooler soon.
    Very easy, just route a hose from the return line on the gearbox to the cooler, then a hose from the cooler to the reservoir and you're done.
    Boss
    89' 1 TON of FUN K5
  3. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I put the heavy duty one on from here www.geocities.com/baja/5099
  4. MaxCrack
    Apr 10, 2001
    895
    Mt View, CA
    Hey, thanks for the link. Did you use the heavy duty two pass power steering cooler or a heavy duty transmission cooler?
  5. Burt4x4
    6,854
    I used this one www.geocities.com/baja/5099
  6. 502Burban
    502Burban 1/2 ton status
    Jun 8, 2001
    379
    Southern California
    I'm running the AGR stuff, too, and will be running a cooler to keep temps down. Although the 2-pass tube-and-fin style coolers will probably do just fine, I like the stacked-plate types like these: community.webshots.com/user/robbrj
  7. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    anyone tried using an automatic rad and running the ps return through the cooler lines in the rad
  8. JungleBoy
    JungleBoy 1/2 ton status
    Jan 31, 2001
    243
    Houston TX
    My 91 Sub V1500 with HD cooling and tow package has a simple tubular PS cooler mounted under the radiator support. Certainly not as good as a stacked plate type, but cheap in a wrecking yard, or easy to fab from steel tubing.
