power steering cooler opinions
Discussion in 'The Garage' started by neverendingproject, Apr 20, 2006.
What should go in to the cooler?
  1. Hydroboost
    2 vote(s)
    10.0%
  2. Power steering
    8 vote(s)
    40.0%
  3. Both
    2 vote(s)
    10.0%
  4. I only voted cause there was a nekkid option. (here)
    8 vote(s)
    40.0%
  1. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Im putting on a power steering cooler, and I have a predicament. I have hydroboost too and im wondering if I should have the hydroboost feed into the cooler, the power steering feed into the cooler or figure a ways to splice them and hook them both up. Both coming from the low pressure side of course. My thinking is that Hydroboost will only flow when I have the brakes on. Is this true?
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    my first naked vote
  3. cwn anwyn
    cwn anwyn 1/2 ton status Premium Member
    Oct 30, 2002
    1,268
    6
    Falcon CO
    I went with the nekkid option also.:D But I would probably go with power steering feeding into it. I would guess it circulates/flows around more than the hydro side. Thats where I would guess more heat is coming from? But I don't know anything on the hydroboost setup.:D
  4. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    I think power steering gets more of a workout when wheelin....
    .02c
  5. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    I too have hydrboost. Last year - before I had a cooler - I lost my p/s pump on a trail. Not fun. We installed the new one at the campsite. When we flushed the lines the power steering return flowed fluid from the get-go, but the brake booster only flowed when applying brakes.
    So I plumbed my cooler on the p/s return line only.
    On an aside, I wouldn't tee the returns together through the cooler. When I first installed my serpentine belt setup I used a standard pump and reservoir with one return. I felt like the the returns teed together there was a slight lag in the steering. Especiallywith brakes applied coincidently enough. Don't notice it happening now with the 2 returns.
  6. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    IIRC the high pressure line runs from the pump to the booster, and the then one low pressure hose runs from the booster to the reservoir and the high pressure hose runs from the booster to the steering box, then another low pressure hose runs from the box to the reservoir. I installed one in my trail rig and put it between the PS return and reservoir, and I believe thats how they are installed on factory equiped trucks.
  7. mrk5
    Apr 20, 2004
    12,349
    1,050
    Northern Colorado
    You've got it right.
  8. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    I'm thinking about adding a PS cooler to my 90 Blazer. I'm wondering what type of cooler you guys used and were did you mount it. Doesn't the cooler have to be mounted lower that the PS pump to prevent all the fluid from flowing back into the pump reservoir?
    Dan..
  9. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
  10. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I'm running a stock cooler from a 91 suburban for now, however I am about to start searching for an m998 military hummer cooler. Its big enough to run hydr boost, hyd clutch fan and p/s with 37's. Should work fine for us.
  11. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    I pulled the oil cooler, trans cooler and power steering cooler of a mid 90's one ton truck.
