Power Steering Cooler?
Discussion in 'The Garage' started by trollporter, Jan 17, 2005.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    Is anyone running a power steering pump cooler with hydo-assist? I'm running Red-Neck Ram and about to replace the pump and was thinking about putting a cooler on it while in the process.
  2. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    I've got the rock ram system and had to add their cooler. The pump kept overheating trying to turn the 44" boggers.
  3. jstevenj
    jstevenj Registered Member
    Aug 28, 2002
    94
    north Miss.
    use a small tranny cooler
    I have hydro assist with 42" swampers. I put a small tranny cooler in the return line and have had no problems with heat. This also gives you a little more volume of fluid.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I found a really nice factory PS cooler at the JY on a Caddy. :cool1:
  5. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
  6. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I don't have hydro but I do have a PS cooler. I wish I had pic's but they got wiped out with the swap over to the new Photo shop. Basically I used a small tranny cooler and mounted it in front of my radiator and routed the lines through a hole in the front grill. My pump was overheating until I put the cooler on. No probs since then!
  7. jekbrown
    May 19, 2001
    45,030
    366
    Vancouver, WA, USA
    i run a small tranny cooler on mine and use the extended filler neck hose trick. I have a WTO hydro assist. Even with a good amount of rock action, my steering resevoir never seems to boil over. Thats a good thing. When I upgrade my big tranny cooler to an even bigger stacked plate cooler Im gonna put the big one in the PS loop. IMO, you can't have too much cooling when it comes to the PS system. Just by its nature it can generate a LOT of heat and do so very quickly.
    j
