Power Steering Cooler
Discussion in 'The Garage' started by 2Dogs, Jun 1, 2003.
  1. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Hey All,
    Do you need to install the cooler lower than the neck of the PS pump - will it drain out and leak if the cooler is higher?
    It seems like I have seen pics of some mounted higher but want to make sure before I make a mess!
    Please post pics of where you mounted yours.
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    Well I did it!!
    Seems to be holding steady with no messes.
    Musta been a stOOpid question...... /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
  3. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    No questions are stupid when you ask them, some of them seem that way afterwards though.... /forums/images/graemlins/thumb.gif
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Why did you need to mount it higher? I mounted mine on the back of my radiator and it seemed like the only decent place to mount it.
    -- Mike
  5. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    I did it on the front of the ac condensor above the oil cooler. I made brackets using 2 existing holes on the valance panel. It was a clean way to route the hoses and it fit perfectly.
    Wish I had a dig-cam......
    Lotta shite behind the grill - I will probably have cooling issues dud to poor airflow if/when I put a new engine in the beast.
