Power Steering Coolers...How do you run yours?
Discussion in 'The Garage' started by zakk, Dec 16, 2002.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Looking into a PS cooler & i dont have room on my frame rails. or none that i feel comfortable with.
    Some people have problems running them on the radiator, as it causes a bit of "belching" of the fluid.
    Any other ideas?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    my stock one is on the underside of the engine crossmember.
  3. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I took one out of a '75 Suburban. It was mounted in the core support, kind of behind the grille and to the side of the radiator.
  4. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    are you worried about it getting smashed or stones from the road being thrown up onto it??
  5. muddysub
    Jun 23, 2001
    10,451
    489
    me? no.
  6. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    I bought the smallest tranny cooler the parts store had (5 1/2 X 11 or so). I routed it in the return line and attached it to some expanded steel in front of my radiator. I used some old gardenhose to protect the lines from chafing.
  7. 86K5TrailBlazer
    86K5TrailBlazer 1/2 ton status
    Apr 24, 2001
    436
    Orange,CA
    im just putting this together [​IMG]
    more Here
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Mine's mounted in front of the radiator. Make sure you mount it so that the hoses are on top if the res. is not above the cooler. Mine has a remote fill from the hydroboost so my hose routing didn't matter much, the res. is above everything.
  9. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The later 80's model blazers had a factory P/S cooler and mounted it under the radiator support just below the radiator.
