Power Steering Flush Poll
Discussion in 'The Garage' started by colbystephens, Jan 9, 2006.
do you flush your p/s?
  1. yes, often (post up how often)
    5 vote(s)
    15.6%
  2. yes, rarely (post up how often)
    5 vote(s)
    15.6%
  3. no.
    13 vote(s)
    40.6%
  4. who cares? i'm nekkid and don't even flush the toilet.
    9 vote(s)
    28.1%
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    ok - how many of you flush your power steering? how often? what are the negative effects of not doing this to a DD?
  2. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Flushed mine once, was on a complete new system. Just wanted to make sure all if any contaminants would come out.
  3. bigchiefmudder
    bigchiefmudder Registered Member
    Feb 28, 2005
    19
    Martinsville Indiana
    i voted no but when i took my old pump lines and box off there was junk inside the pump and lines. So when i get some time on the new stuff i will prolly drain and flush after spending the $$$$ on new stuff
  4. sweetk30
    Nov 1, 2004
    25,539
    539
    horseheads , ny 14845
    good to do. heat kills the fluid and if you have big tires and hydro boost or hydro steering it heats up faster.
    fords are the worst system for dirty. and when thay start to make the growling sound its time to flush them. and it will shut them up and act smotther.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    you have a diesel with hydro boost so it prolly cant hurt to do it more cause your runs your brakes too:eek1:
  6. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    actually, this isn't in regard to my diesel rig. besides - the motor is out of that one, completely torn apart and at the machine shop - so there's no powersteering to deal with right now anyway - it's all drained and waiting to be reinstalled. :) this is actually in regard to a '93ish lexus sedan my father in law just bought. i didn't specify, b/c i didn't think it really mattered - it's always good info for future use for all makes. anyway, he had his mechanic look at it and i'm trying to decide if the maintinence things the mechanic said to do were just to make an extra buck. i'll be doing the work for him no matter the case, so the mechanic actually won't get anything. i just don't want to do something i don't need to - i hate working on little cars. i'm kinda thinking it doesn't really make that much of a difference on this car. i'll do it for him no matter the case if he wants, but i'm trying to also figure out if his mechanic is honest, or just in it for the cash. the father in law has had lots of trouble with that and doesn't know anything about cars, so i try to watch out for him. whatever. thanks for the replies.
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I am installing junkyard hydroboost and crossover and a cooler how would you go about flushing said power steering system?
    Ira
  8. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    I dont flush the whole system but I usually drain the pump once a year and refill with clean fluid. I have always done this on all my cars n trucks. It must do some good because I have never had a PS pump go out on me.
  9. SchnorrCS
    SchnorrCS 1/2 ton status
    Oct 11, 2005
    368
    Loveland, CO
    How do you flush the power steering system?
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Mine "self flushes" all of the time due to the bad seal.
  11. GotLabs
    GotLabs 1/2 ton status GMOTM Winner
    Jul 30, 2005
    2,795
    Transient, USA
    Dude, if I get really trashed I p my pants!!
  12. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i'm very sorry to hear that.
  13. K30CJ
    K30CJ 1/2 ton status
    May 16, 2003
    429
    IN
    I don't flush. When I lean it over hard, or flop it on it's side, I loose a little fluid. It gets fresh fluid when I refill. That, and I have a PS filter. I would flush an old truck's fluid though when it's been in there for who-knows-how-long.:D
  14. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    To flush a system with hydroboost:
    1. connect 6 foot piece of hose to drain hose nipple on hydroboost unit (preferably clear).
    2. Route hose over driver side fender to bottle on ground.
    3. Fill reservoir to top
    4. Start and idle engine, have someone turn steering wheel side-to-side, this will drain fluid faster. Drain a small amount at a time, stop engine, refill reservoir. Do not drain too much, the pump will make some bad sounds. I do this until the system consumes a full quart of fluid.
    Anyone with a ford, especially a diesel should be well versed in this procedure. The hydroboost system for ford is no where near as strong as a chevy. One of these days a chevy pump is going on my super duty!
