Power steering Gear Box?? Quickie I need Help
Discussion in 'The Garage' started by Mudbug1979, Dec 15, 2003.
  1. Mudbug1979
    Mudbug1979 1/2 ton status
    Aug 4, 2002
    439
    Monroe,North Carolina
    Which side of the power steering is the pressure side and which is the return. I installed a used one that I got for a pretty good deal and not sure If I installed the lines wrong. If you are looking throught the fender at the box the line closest to you is blowing fluid out around the threads of the fitting. /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/confused.gif
  2. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    There is a fool proof system for that. One of the lines should have a bigger fitting on it. Be careful though, there are two types of fittings runnin around out there. One style comes to a more of a point with a flared reciever in the box and the other flare out with a point style reciever in the box. It sounds goofey but if you look close you can see the difference (I found my truck is in that don't go by a-zones compter year, 1980 with all 1979 parts)
  3. Mudbug1979
    Aug 4, 2002
    439
    My truck is a 79 and the box came off of a 87 3/4 ton. Only one line is leaking. I was wondering if I could put some teflon tape on it to keep it from leaking.
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Did you change the hoses also? Cause in 81 the gear boxes were changed to an O-ring seal versus the flare fitting style. That could be causing your leaking, not a goo seal cause of the different types of fittings.
  5. dyeager535
    26,979
    Pressure side is the one that threads into the PS pump.
    You can change out the threaded portion of the pumps, so that you can use the old lines on the new pump, which is a necessity if you don't change your gearbox to the newer "metric" style.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    80 was first year of o ring hoses, 79 last for nornal flared,
    fittings are two different thread sizes, you cant get them wrong and the low hosze is clamped together and the hi side hose is hydraulic press made and will not come apart, it threads into back of pump
