power steering gear box sprung a leak
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrappyk5, Dec 9, 2006.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    my gear box is leaking around the seal where the steering shaft connects.
    is that repairable or do i need another gearbox ?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    That is an easy one.
    You can just change the seal right there, you will need to take off the pitman arm but you can keep the box in the truck.
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
  4. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    thanks "cbbr"
    i should have searched first.:D
    this is doable, and alot cheaper than a remf one.
  5. cbbr
    Jul 17, 2004
    14,681
    The search on that topic turns up a ton of stuff. I book marked from when I had the same problem and got a lot of help.
