Power Steering Hard lines!!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NAUBlazer, Mar 20, 2003.
  1. NAUBlazer
    NAUBlazer Registered Member
    Dec 3, 2002
    18
    Chandler, AZ
    Ok guys heres the problem...Im replacing the power steering pump on my 81 w/350. I'm having alot of trouble getting the hard line off of the steering box. Is it ok to apply heat to something like that, or am i going to destroy the steering box. I already tried some liquid wrench so i'm out of ideas. Thanks for the input guys
    --Adam /forums/images/graemlins/k5.gif
  2. Polaris
    Polaris 1/2 ton status
    May 30, 2002
    1,182
    Rhinelander, Wisconsin
    I can't say for sure on the torch, but I do know there is a rubber o-ring you need to look out for. My secret is a flare wrench (line wrench, whatever) and a few good taps with a hammer. I'm not a real big person and the hammer sure helps me out!
  3. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    vice-grips and a cheater bar. (you may have to be creative you get a cheater bar on vice grips though)
  4. NAUBlazer
    Dec 3, 2002
    18
    Chandler, AZ
    Do you guys think a pipe wrench would work? This was the suggestion from my girlfriends dad.
  5. 4x4_76
    4x4_76 1/2 ton status
    Jul 22, 2001
    628
    Ylämaa, Finland
    Few taps to the side of the box,right next to fitting.That's how my brother took off our cousins STW's hard line.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah if penetrating oil and some taps dont work then go for pipe wrench, use alot of oil if at all possible, good oil not cheap auto zone crap, go to napa and get PB Blaster, its worth its weight in gold
  7. Bob Hope
    Bob Hope Registered Member
    Feb 25, 2003
    14
    Pinconning, MI
    torching it will destroy the seals in the gearbox. not a good idea unless you want to replace it. Do you really need to take the line off the gear to replace the pump?
