power steering help
Discussion in 'The Garage' started by dheavychevy38, Feb 4, 2007.
  1. dheavychevy38
    dheavychevy38 1/2 ton status Premium Member
    Jan 6, 2003
    1,003
    Algonquin,illinois
    Ok i have a 97 chevy 3/4 4x4 with the 6.5 in her.Heres the problem last night i went to start her and the steering was rock hard after a while of sitting there it started to work then the pump was gowling. I popped the hood and the cap for the power steering pump was in 2 pieces and blown off the pump.So i got a new cap and filled her up everything was fine. Went to leave buddys house last night and it did it again any ideas the pump is 6months old. Thanks Denny
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    My 98 would lock up once in a while like that. Never blew the cap of the res. though.
    Turns out I had destroyed nearly everything inside the steering gear. The Sector shaft and outer end of the worm gear were about the only good parts left.
  3. dheavychevy38
    Jan 6, 2003
    1,003
    Algonquin,illinois
    This is my daily driver and has never done this before and i have not hit anything like that or abused it to the point that the internals should be shot.
