Power steering hose Q's
Discussion in 'The Garage' started by southernspeed, Jan 22, 2006.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    On the later style power steering hoses, the high pressure side has an 'o' ring on each end (pump and box), should the low pressure side have one where it comes out of the box? Mine hasn't but I don't know if I've been careless and dropped it or if they just don't have one.
    Anyone got one stripped or have a parts book?
    Thanks.:D
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    When I rebuilt my neighbors 87 it had o-rings on each line at the box. Not sure about the pump end as we never disconnected it.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    All the ends have o-rings except for the return to the pump. It just slides over the little pipe on the pump resevoir and gets attached with a hose clamp.
    Ira
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Ok, thanks. I figured there should be. i guess I dropped one as I pulled it off. Well....that's well and truly jet-washed away now! I bet none of the dealers over here have them in stock either!
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    Any parts store will have a selection of O-rings that can be used with power steering. You just need to look at the sizes and pick the correct one.
